CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
123 registered members (14Accent, 1WildPig, 240_Ed, 380SLbenz, 1978elcamino, 11 invisible), 2,108 guests, and 52 spiders.
Topics286,202
Posts4,904,104
Members67,576
Most Online2,967
Mar 10th, 2019
Page 1 of 6 1 2 6
DEXRONŽ-HP spec (GMW16974) published #3118711
09/08/13 04:55 PM
09/08/13 04:55 PM
Los Angeles, California
Gokhan Online content OP
Gokhan  Online Content OP
Here comes the latest in ATF technology -- DEXRONŽ-HP. It is probably backward compatible with DEXRONŽ-VI. It's fully synthetic, possibly PAO-based:
GMW16974
DEXRON High Performance Automatic Transmission Fluid (DEXRON HP-ATF)
Material Description. This full synthetic base oil specification covers DEXRONŽ Automatic Transmission Fluid (ATF) primarily for use in General Motors automatic transmissions. This specification describes, in terms of laboratory and simulated service test results, the requirements for a minimum-performance fluid. The primary requirement is satisfactory performance in normally functioning transmissions under normal and severe conditions. Symbols. Not applicable. Typical Applications. This lubricant is to be used in GM automatic transmissions and other specified applications. Remarks. This specification may involve hazardous materials, operations, and equipment. This specification does not purport to address all of the safety problems associated with its use. It is the responsibility of the user of this specification to establish appropriate safety and health practices and to determine the applicability of regulatory limitations prior to use. This specification uses the International System of Units (SI) as standard per IEEE/ASTM SI 10, except for certain components which are commercially available only in American conventional units. This specification uses the Rounding-Off Method per ASTM E29 for significant figures to determine conformance to specification requirements. Unless otherwise noted, part numbers of this specification refer to those of General Motors Powertrain.
Edition: Issue 1; English
Publisher: GMW
Language: en;
Published Date: 2013-07-01
Document Number: GMW16974
Document Status: Current (Active)
1985 Toyota Corolla LE, 4A-LC engine, ~ 273,000 M
Mobil 1 Extended Performance 0W-20 SN PLUS (PAO-based)
Fram Ultra XG3600 filter (full synthetic), 90430-12031 drain gasket (rubber on aluminum)
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3118718
09/08/13 05:00 PM
09/08/13 05:00 PM
Rochester, MI, US, World
Klutch9 Offline
Klutch9  Offline
Nice. Now it's only a matter of time before people start calling it DEXTRON HP. Haha.
'11 Fusion SE 2.5L - 83k miles - HK 0w20 syn, Wix XP filter
'08 Sedona LX LWB 3.8L - 129k miles - Havoline HM 5w20, Auto7 filter
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3118721
09/08/13 05:03 PM
09/08/13 05:03 PM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
I'm looking forward to this. Dexron-VI was a great improvement over Dexron-III H and was developed mainly for their new 6 speed transmissions. Wonder what the primary application for Dexron-HP will be.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3118746
09/08/13 05:35 PM
09/08/13 05:35 PM
USA
NHGUY Offline
NHGUY  Offline
USA
Yet another fluid auto parts stores have to stock.
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Klutch9] #3118748
09/08/13 05:37 PM
09/08/13 05:37 PM
Fla
63Marauder Offline
63Marauder  Offline
Fla
I love dextron !
2014 Ford F150 5L. 1963 Mercury Marauder.
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3118866
09/08/13 07:43 PM
09/08/13 07:43 PM
Rockwall, Texas
Old Mustang Guy Online content
Old Mustang Guy  Online Content
Rockwall, Texas
What do they mean by "minimum performance"?
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3118867
09/08/13 07:45 PM
09/08/13 07:45 PM
Rockwall, Texas
Rockwall, Texas
I guess it refers to the spec, not the fluid.
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Old Mustang Guy] #3118893
09/08/13 08:14 PM
09/08/13 08:14 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Depending upon what kind of spec line item it is, there always is a minimum or a not to exceed requirement for the various parameters of interest. If they werent bounded, there wouldnt be a point to having a spec...
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3527995
11/02/14 04:09 PM
11/02/14 04:09 PM
Portland, OR
Nate1979 Offline
Nate1979  Offline
Portland, OR
Bumping an old thread. I saw an owners manual lists Dexron HP as the fluid for the new Silverado 8speed transmission.
Anyone know any details yet about this fluid?
2015 GMC Sierra 2500 6.0L
2010 Subaru Forester 2.5X
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3528554
11/03/14 09:24 AM
11/03/14 09:24 AM
MI, USA
Whitewolf Offline
Whitewolf  Offline
MI, USA
GM part #9986333.
Synthetic (real) PAO see OEM/Lube News Jan 7 2013.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3666442
03/16/15 12:27 AM
03/16/15 12:27 AM
SE TN
BigLee Offline
BigLee  Offline
SE TN
Just noticed we had some Dexron HP in our parts dept. the other day.
just wondering if anybody had any viscosity or other specs on this fluid yet.
BTW, the U.S. GM part # for quart bottle is 19300536.
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: BigLee] #3666575
03/16/15 06:52 AM
03/16/15 06:52 AM
MI, USA
Whitewolf Offline
Whitewolf  Offline
MI, USA
I think I can help you with that.
KV 100C 5.95 cSt, KV 40C 28.1 cSt, BV @ -40C 5,000 cP, CCS -25C 978 MPa-s, CCS -30C 1520 MPa-s.
Minimum spec means that any fluid wanting to be approved as a DEXRON HP fluid must be at least as good as the original approved product in ALL respects.
~ PJ Plauger
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: BigLee] #3666585
03/16/15 07:09 AM
03/16/15 07:09 AM
MI, USA
Whitewolf Offline
Whitewolf  Offline
MI, USA
Just out of interest what's the price?
~ PJ Plauger
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Gokhan] #3666592
03/16/15 07:15 AM
03/16/15 07:15 AM
Paradise of Florida
Greasymechtech Offline
Paradise of Florida
At $25/qt, I don't expect it to be in stock in too many autopart stores or wallyworld.
I wonder if its backwards compatible with Dexron-6 for us that ski frigid mountains and travel around Canada/Alaska?????
At what point should a lurker start posting :-)
Re: DEXRONŽ-HP spec (GMW-16974) published [Re: Greasymechtech] #3666635
03/16/15 07:59 AM
03/16/15 07:59 AM
MI, USA
Whitewolf Offline
Whitewolf  Offline
MI, USA
Yes it is. The only problem is that the more normal DEXRON-VI you have mixed in with it then the more DEXRON-HP benefit you lose.
~ PJ Plauger
Page 1 of 6 1 2 6
