I have a 2010 ford transit connect. Since 30K miles (now at 115K) I have had serious lunging and scraping/squeaking sounds out of the rear brakes. I have tried replacing the drums and pads twice and resurfaced the drums a couple of times as well.
When new or freshly machined, the braking is nice and smooth. the more the pads bed in, the worse the symptoms get. I have had the dealer do most of the work although I have had other mechanics do some of the work trying to get second opinions.
I have done quite a bit of research on the internet thinking it may be the rear wheel bearing on both rear wheels going bad.
My theory: the bearings are loose or "sagging" causing a mis-alignment of the hub and pad. they are not making the lunging and scraping sounds when the hubs are new or freshly machined because the pads are not biting in to the hubs and just smoothly skimming across. but when the part that is making better contact with the hub starts bedding in, its causing the lunging etc. The only thing is that while driving along they do not make any sound though I have heard they can go bad without making noise.
the problem is the bearings are EXPENSIVE to the tune of at least $250 each. $500 plus labor is hard to swallow on a hunch and if it doesn't work Im gonna be really disappointed.
any advice would help..thanks
