I just took a 1980 AMC 258 out of a CJ-7 apart for the 12 counterweight crankshaft and 707 rods. The 12 weight crankshaft weights 66lbs! The 4 counterweight cranks they used in the 1981 thru 1990 AMC 258s, pretty much just in last year CJs and first year YJs(1987-1990) weighs an amazing to me 20lbs less at 46 lbs. A Jeep 4.0 crank of any year comes in at 55lbs. This 1980 258 crank I have has been ground -.010, for the rebuild the 258 had previously, but only needed a polish from machine shop. Rods need to be checked for stretch and straightness, and I would like to install new ARP bolts, then New Sealed Power 4.0 standard bore pistons will then be pressed on for a mere $40. Then Into my awaiting 2000 Jeep XJ 4.0 for what Im going to call it "Dirty Light Hone 4.5", if I had bore Her .020 or .030 She would be a 4.6Liter and .060 would make Her a Dirty OverBore 4.7, offset ground crank goes to 4.8Liter and take .125 out of Her Walls, stuff Chevy 4" pistons for a 5.0Liter FourPointOh!
