The 14612 has a lot more pleats than the 14610, while the 14610 has a thicker media (probably higher efficiency).
The 14612 is just the short version of the 14610. I don't see how the 14612 could have more pleats or media area than the 14610. I've used 14610s on my V6 Altima and have cut open quite a few. The PL14610 has 59 pleats and ~105 sq-in of media. I highly doubt the PL14612 has more.
And as far as efficiency ... look at the fine print on the filter box. Both the PL14612 and the PL14610 are rated at "99.9% @ 40 microns". It's printed right on the box. These two filters are two of the only 4 spin-ons that Purolator rates at 40 microns (for some unknown reason). I highly doubt the media is different between a PL14612 and a PL14610.
See my thread where I cut them open:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1855050
The pennzoil is a 14610. Thicker media, less pleats, but could very well have the same or more sq inches of media. I counted 34 pleats on the 14610 versus 52 on the 14612. So if you have 59 on yours then the 14610 has changed since the last time I opened one.
The Pennzoil is a Pennzoil "version" of a Purolator 14610 ... it is NOT a Purolator 14610 filter, but a "re-specified clone" built for Pennzoil by Purolator.
Purolator makes the Pennzoil filter to Pennzoil's specs. Pennzoil could specify it only has 5 pleats, and Purolator would make it to Pennzoil's design specs.
You are comparing apples to oranges.
The 14610's I've cut open over the years were like that pennzoil filter. That being said it's been a couple years since I cut one. I'm looking forward to opening up the ones on my shelf now.
Here's one from another member that probably has max 40:
Like I said, if you've cut open a 14610 with 50+ pleats with thin media then it has changed from the several that I've cut open over the years and I would love to see your pics.
The thinner media in the 14612 is strong as nails because of the number of pleats and size of the filter. Therefore I would only use the 14610 if it had as many, or more, pleats to have the same strength. Otherwise the thinner media in a longer filter will result in wavy/inconsistent media at the end of an OCI (which isn't the end of the world, but not my preference). I sure hope the ones in my stash are solid like I assumed...
