I've always heard people complain (online) about aftermarket parts store tensioners more than belts. I would use either a Dayco or Gates belt.
If you're going to do TB, tensioner and water pump, if any one of those parts is bad, you have to do it all again, so it makes sense to go with good stuff.
On an interference engine I would prefer manufacturer or OEM brand belts, tensioners and water pumps. Parts store stuff may have a lifetime warranty on the parts but that won't fix the damage a bad part could do.
