Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
Mobil 1 FS 0w40 vs Castrol 0w40
by Ndx - 11/12/19 04:14 PM
How often to drive a second car.
by SouthDakotaDad - 11/12/19 03:48 PM
Manufacturers, Bypasses & Large Sumps
by ad244 - 11/12/19 03:23 PM
Samsung DeX for PC
by dogememe - 11/12/19 03:19 PM
2008 Acura TL Timing Belt/Component Kit
by BAJA_05 - 11/12/19 02:06 PM
Installing decals and emblems in cold weather
by atikovi - 11/12/19 01:39 PM
Skyactiv 20,000 mile OCI with Oil Analysis
by thegameq - 11/12/19 01:23 PM
Stihl KM110R Carburetor Adjustment
by henni - 11/12/19 01:10 PM
Mix and match wheel cylinder brands?
by RocketUSA - 11/12/19 12:45 PM
Hombre909, DeLong, Scuder, Jasonrmcc, Capacc
69840 Registered Users
120 registered members (1978elcamino, 2010Civic, 928, 69Torino, 2002 Maxima SE, 14 invisible), 2,129 guests, and 23 spiders.
Topics297,332
Posts5,113,208
Members69,840
Most Online3,589
Nov 2nd, 2019
Why is 10w30 "preferred" for jeep I-6? #3111990 09/01/13 04:55 PM
2
2000NWXJ Offline OP
2
The manual says that 10w30 is preferred and to use 5w30 if you experience sub zero temps. I'm assuming because the oil clings to the parts a little better. My instincts tell me to take it down to 5w so I can get better flow at startup but I can't help but think the engineers chose 10w for a specific reason. I know lots of people run 5w40 and 15w40 in this engine as well so if anyone could give me some insight that would be great. I've already decided on rotella with a pureone filter for my next oil change all I have to do now is settle on a viscosity.
2000 Jeep Cherokee Classic (XJ) 4.0 I-6
Delo 400 XLE Synblend SAE 10w30
Purolator PureONE
Re: Why is 10w30 "preferred" for jeep I-6? [Re: 2000NWXJ] #3112007 09/01/13 05:24 PM
Z
Zaedock Offline
Z
Typically, the 10W30 lubricants of yesteryear were more robust than their 5W30 counterparts, which could shear down into the 20wt viscosity range. Fast forward to the present and 5W30 conventional lubes have drastically improved.
Being a Jeep guy and having rebuilt many Jeep engines, a modern 5W30 conventional should serve you well. I recommend SOPUS products, as they are quality lubes at a great price.
Many here on BITOG have posted UOA info on various oils used in the Jeep/AMC 4.0L. Typically, this design is known to shed some iron. Heavy 30wt or 40wt oils usually produce the lowest Fe numbers. In my experience, I have run SAE30, 10W30, & 10W40 all with great numbers, but for the last several years, I have run Quaker State GRPIII synthetic 5W30 in my trail Jeep's 2.5L. I have obtained similar Fe numbers running this oil and appreciate the quicker revs and lower parasitic drag compared to heavier oils.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Why is 10w30 "preferred" for jeep I-6? [Re: 2000NWXJ] #3112024 09/01/13 05:48 PM
Y
y_p_w Offline
Y
Same was true for GM 3800 Series II engines from the 90s.
The 5W-30 oils at the time were probably more volatile. 20 years later and the API SN standard is easily better.
Re: Why is 10w30 "preferred" for jeep I-6? [Re: 2000NWXJ] #3112036 09/01/13 05:57 PM
9
901Memphis Offline
9
T6 5w40 is popular and UOAs seem to back it up. GC 0w30 is another option as its on the higher end of a 30 grade.
2012 Chevy Cruze LT 1.4T - 69k - M1HM 5w30 + Fram Ultra
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Why is 10w30 "preferred" for jeep I-6? [Re: 2000NWXJ] #3112067 09/01/13 06:30 PM
K
KCJeep Offline
K
The Jeep 4.0 will seem to run fine on a 5w30 but if you do a UOA and it has sheared it won't be pretty. It needs a good 30 grade, thus the 10w30 recommendation and frankly a thick 30 is even better, like Rotella or Defy.
If you must run 5w30 use Valvoline, multiple UOA's in the 4.0 have shown it to have above average shear resistance and it produces excellent "wear" numbers in the 4.0 too.
2018 VW Passat GT VR6 - 18k - Castrol Pro OE 5w40 - VW OEM filter
2012 KIA Sedona 103k - Valvoline Maxlife 5w30
2012 VW Tiguan 102k - Castrol 0w40
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: Why is 10w30 "preferred" for jeep I-6? [Re: 2000NWXJ] #3112079 09/01/13 06:42 PM
T
Thax Offline
T
The 4.0L runs best on a thicker 10w-30 such as QS Defy 10w-30 , Rotella T5 . Other good lubes for this engine are PYB or VWB . I run Defy 10w-30 and am very happy with the results.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: Why is 10w30 "preferred" for jeep I-6? [Re: y_p_w] #3112134 09/01/13 07:52 PM
B
beast3300 Offline
B
Incidentally the 87-89 3800's SI recommended 5w30 until the "Tuned port" 3800 came out in the Regal GS in 1990. The 3300 from 89-90 also suggested 5w30 and switched to 10w30 for 91-93. In 2003 the 3800s suggested 5w30 again. Don't ask why I know this worthless info, lol.
As for the O.P. I think the Jeep 4L was in the same boat as the 3800 as far as the 10w30 suggestion. During that time period the 5w30s weren't holding up is my guess.
Having said that....I ran 95% of the time 5w30 conventional/blends/full syn in my 98 Regal for 6 years. That engine (which is in my garage) has 221,xxx original miles on it and has seen about 75 drag strip passes (not counting the multiple street floggings).
5w30 should serve you well. That's what we put in them at work. However there are some evidence that maybe a HDEO would be a better choice for the 4L.
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: Why is 10w30 "preferred" for jeep I-6? [Re: 2000NWXJ] #3112218 09/01/13 08:55 PM
K
KCJeep Offline
K
That's the problem with the 5w30's, they run great you think it's fine but if you do a UOA you'll often find you could've done much better.
A 4.0 will usually shear a typical 5w30 with a [email protected] of 10.5 down to about 9 in only 3,000 miles. At that point it's too thin for optimum protection, the 4.0 needs thicker lube than that.
It will also do the same thing to lesser 10w30's, so if running a standard thickness 10w30 a top quality name brand needs to be the choice. Valvoline has been the stand out in this bracket Maxlife or White bottle no matter. Better yet though is a quality 10w30 on the thick side, like Rotella or Defy.
Ironically I can count the "good" UOA's I've seen for the 4.0 using top tier synthetics on the fingers of one hand with some left over. The 4.0 thrives on a good dino or at most a syn blend like Maxlife or T5.
