OVERKILL
$100 Site Donor 2021
Originally Posted By: bluesubie
So in other words, you don't know. I'm still looking for a document that specifically states "W" stands for winter (not that it denotes multi-viscosity oil for winter usage).
Quote:
To correct this problem, a new low-temperature classification was eventually added to the Standard in 1950, and it became possible to grade oils by a low-temperature W-grade designation, such as SAE 5W, 10W, or 20W. Now the consumer could ask specifically for an SAE 5W grade, at that time the lowest of the three low-viscosity SAE W-grades, for cold weather driving, or an SAE 40 grade, for example, for summer operation.
http://www.sae.org/news/releases/rightoil.htm
-Dennis
Dennis:
You appear to have missed my SAE quote from above:
Originally Posted By: SAE
It was recognized by 1930 that a classification for winter oils must be based on the viscosity of the oil at the starting temperature, and work was started on this problem. In June, 1933, the 10-W and 20-W oils, which are classified in accord with their viscosity at 0 deg. fahr., were adopted for publication and trial.
http://papers.sae.org/340098/
-Dennis
Dennis:
