Originally Posted By: olskoolblu
I'm not sure I understand, aren't automatic trans made of wet clutch packs? Harley aftermarket clutch makers recommend ATF.
Maybe they use something special for the friction material,I don't know.
What I do know for fact that a brother rides an 02 or 03 police bike. He has gone thru 3 clutches in 5 years using tranny fluid in his primary. He is an experienced rider and gets Harley to fix his bike.
He read on the net to use tranny fluid and he is too stubborn to change. So every 15000 miles its back in for a new clutch.
I've ridden bikes since I was 6 years old. I've ridden imports mostly,this is my first Harley,but power stunk so I built an S&S 106,woods cams,ported heads,milled for compression.
I've got 100tq at 2200rpm. And my stock clutch doesn't slip whatsoever,even when I crank on it,no slip.
All my years riding imports,a couple 1100 virago's,an 1100 v-star,an 1100 and 750 shadow etc and I've always come back to rotella after trying syn here and there. I've never replaced a clutch,nor wore one out,ever,using rotella.
And its cheap and says right on it JASO. So in my head I think its not worth the risk,nor potential expense because rotella meets the spec,and its cheap.
I change it when I change the oil. Its cheap enough that I'm not trying to get any return on investment and I get it in 5 gallon pails for my shared sump bikes(3) and my Harley.
And I can honestly say my top end on my Harley has never been quieter. Never. And its got a bit more pep using rotella in the engine.
So I just don't over think it. It meets JASO which means perfect in my primary,and it runs beautifully in my engine.
Now I use 1 oil in everything except my tranny. Redline is the best I've used so I'm sticking with it,otherwise rotella is great.
