Originally Posted By: TechnoLoGs
What are some of the best gun oils, and what gun parts do they lubricate?
Only thing I can think of is the slide on semi-automatics, and I heard Glocks "like not a lot of oil." Could be 100% wrong, but. Please explain?
I use Slick 50 One Lube on all of my firearms( one exception - see below ). I have had excellent success with it. Well, the original formula. They have recently reformulated it and I am hoping the new stuff is at least as good. You can all save the Slick 50 jokes too as this stuff really works great.
http://www.slick50.com/ourProducts/oneLube.shtml
I use it everywhere on the gun except the stock and forearm. Basically all metal parts( i.e. working parts and exterior ). it works really, REALLY, well. It keeps the working parts properly lubed without attracting a lot of powder residue and turning it into a concrete like substance( a big problem with many lubes ). When used on the exterior it keeps it sealed/protected without being greasy or slippery( even though I spray the gun down heavily and let it sit and dry ). Not one spot of rust on any of my guns since swapping to it.
I am a big waterfowl hunter. That means hunting in some god awful conditions( rain, snow, sleet, extreme cold, mud, etc... ). Also, I only hunt out on the coast so that means saltwater. Saltwater and guns don't mix well. I put my gun through some real abuse. The oil/protectant I use is very important or the gun won't function when needed and/or will rust away.
I have tried all the popular traditional gun oils and find them lacking. Have tried many different general purpose lubricant sprays with varying success. Grabbed a can of One Lube at the local ACE hardware about 5+ years back for my boat and ended up using it on my gun as I was out of the stuff I was using( Castle Big5 silicone spray ). Haven't looked back since.
The only time I don't use it is in the dead of winter, when the temps really drop, on my semi auto shotgun. In extreme cold it can get a little thick and that slows the action down on my gun. For those times I use Royal Purple gun oil which is synthetic and isn't effected by the cold as bad. Pretty much I just use the RP on the return spring and the bolt slides, during extreme cold periods, as it is $10+ a can.
http://royalpurpleconsumer.com/product-categories/other/#!royal-purple-synthetic-gun-oil
As said above, Slick 50 recently reformulated One Lube. I hope it is still as good? Says it uses some synthetic additives now( don't think it did before? )so maybe I no longer need the RP gun oil in the cold? I will find out this winter I guess.
I have some expensive guns that are not out of the gun cabinet much as well. The One Lube does a great job on long term storage too. I clean all my stored guns every year but I swear they could go many years without any rust.
I used up my last can of the original stuff( red can w/ black cap )last week. I noticed when I stopped by the store to grab a couple cans that it is an all new can and new formula( says Supercharged on the can now ). I grabbed 3 cans and really hope it works as good as the original. I would hate the have to go back on the search for a new product to use. Especially since the original formula was almost perfect.
Slick 50 One Lube is available at ACE hardware and also Napa. Those are 2 places I know of anyway. About $5 a can. I highly recommend it.
