Originally Posted By: hypervish
Originally Posted By: Tegger
Originally Posted By: berniedd
The "idle up" circuit mentioned above is the idle air control valve (IACV). It is essentially an additional air bypass that is mounted ahead of the throttle plate. It is opened up by the computer when an additional engine load is sensed
That's the point: the load must be sensed before the IACV is commanded to open by the ECM/PCM! The IACV doesn't just open up on its own! The A/C signal is sent to the ECM, the ECM thus becomes aware that the A/C has been activated, then it commands the IACV to open (and adjusts the fuel mixture to match) so the idle will remain steady.
If the ECM/PCM is not told that the A/C is on (no A/C signal sent), then it won't know to boost the idle to compensate for the load and you'll get idle vibration. If the vehicle has a tach, this problem will be very obvious, as the needle will drop and not recover. The Check Engine light may also be on.
And the OP never said what year Honda. Earlier vehicles had more secondary air inputs than just the IACV.
It's a 2003 according the subject title.
Yup, it's a 2003. No check engine light but apparantly the SRS light comes on (oh great another issue). Thanks for all of the advice guys. I'm going to print this out and let my buddy read it so he knows what to look for and what may be the cause of his issue.
