There actually wasn't that much dust in the area under the handguard. Most certainly not enough to cause the stoppages. The recoil spring and guide rod were dusty, but again not exceptionally so.
The areas that retained dust and caused the majority of the stoppages were the op rod track in the receiver and the camming area of the op rod. Dust infiltration in the extractor clearance in the bolt may have been causing the FTExtract.
BSW [/quote]
Interesting, The mini-14 does have open operating surfaces like that and I could see how that would jam things up. It seemed to me like the bolt operation was unusually slow, like the piston was jammed up and slowed down. Did you grease or oil the op rod track and bolt cam? It really makes me wonder if a dry lube like ezzox would have prevented the jamming. Normally dirt and grit on the outside of the mini's bolt just gets blown off during recoil. And again, the 18- series of mini's were so poorly machined.... Lots of variables there.
BSW [/quote]
