Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
63 registered members (andyd, AZjeff, AdditiveOCD, atikovi, A_A_G, AdmdeVilleneuve, 7 invisible), 1,415 guests, and 41 spiders.
Topics295,007
Posts4,925,827
Members66,664
Most Online2,553
Oct 27th, 2018
New Selenia direct injection specific lube #3081547
07/31/13 04:19 AM
07/31/13 04:19 AM
Australia
supercity Offline OP
Australia
Owners of new Alfa Romeos with the 1750tbi (GDI) engine noted the oil recommended by the dealers had changed from Selenia Star PE 5w40 ACEA C3 to this new Selenia Sport Power 5w40 ACEA C3 FIAT 9.55535-GH2 without any explanation why. What made it worse was the service bulletin circulating and warning "The use of products with different specifications than those indicated above could cause damage to the engine not covered by the warranty". There was no information on Selenia's website as to the reason or what sort of damaged Selenia Star PE had done so speculation was rife, a lot of people thought the lube was to combat turbo failures.
Anyway Selenia has finally released some info (above) and it appears the new lube is specific for direct injection applications. It holds the sole description "a fully synthetic lubricant especially designed to enhance the sporting characteristics of direct injection petrol engines(GDI)" I wonder how good really is and what they have done?
Re: New Selenia direct injection specific lube [Re: supercity] #3081648
07/31/13 07:08 AM
07/31/13 07:08 AM
PA
d00df00d Offline
d00df00d  Offline
PA
Good question.
Selenia's data sheet is... lacking...
2008 BMW M3
Re: New Selenia direct injection specific lube [Re: supercity] #3084662
08/03/13 02:28 PM
08/03/13 02:28 PM
Gone
pscholte Offline
pscholte  Offline
Gone
Might be a translation thing but I don't know about an oil designed to enhance the sporting characteristics of direct injection petrol engines(GDI). Not sure I have ever seen an oil that enhanced characteristics before.
Re: New Selenia direct injection specific lube [Re: pscholte] #3084795
08/03/13 05:32 PM
08/03/13 05:32 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
I have owned several Italian cars (Lancia and Alfa), and I learned one thing: Never doubt Selenia Oil!!
15' Toyota Sienna AWD (Mobil1 0W20 EP+ 2qt of M1 0W40 + FRAM Ultra).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: New Selenia direct injection specific lube [Re: supercity] #3088561
08/07/13 11:27 AM
08/07/13 11:27 AM
Southeastern, USA
camelCase Offline
camelCase  Offline
Southeastern, USA
My guess is they are trying new additives and bases (notice the ester mix) to help prevent oil from turning into a solid deposit when it hits a hot surface (such as an intake valve). The absolute specifics are still a mystery for now.
Re: New Selenia direct injection specific lube [Re: supercity] #4648119
01/27/18 03:38 PM
01/27/18 03:38 PM
Israel
Croc Offline
Croc  Offline
Israel
Recently purchased S/H Alfa Romeo 4c.
The owner's manual states 5W-40 ACEA C3 + FIAT 9.55535-GH2.
They recommend Selenia Sport 5w40.
Those are its specs:
http://www.extranetpli.eu.petronas.com/dsp/pdf/ENG/stec/1636_stec_ENG.pdf
http://www.extranetpli.eu.petronas.com/dsp/pdf/ENG/ssic/1636_ssic_ENG.pdf
Do you think other C3 oils can be used?
I see Valvoline SynPower MST C3 and Motul X-Clean are C3.
But nothing that i'm familiar with is 9.55535-GH2....
Thanks !!!
Re: New Selenia direct injection specific lube [Re: supercity] #4649619
01/28/18 09:52 PM
01/28/18 09:52 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Very much like to know what a 9.55535-GH2 has, that a C3 doesn't ?
Re: New Selenia direct injection specific lube [Re: zeng] #4649739
01/29/18 04:25 AM
01/29/18 04:25 AM
Rijeka, EU
chrisri Offline
chrisri  Offline
Rijeka, EU
Maximum NOACK limit of 10% for start. There are probably other FCA specifics that we'll never know.
Personally, if out of warranty, I would be fine with LL-04 ,229.51. Certainly wouldn't mind OEM Selenia, but would not go out of my way to find it.
02 Nissan Terrano 2.7.TDi Motul 15w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
Re: New Selenia direct injection specific lube [Re: supercity] #4649748
01/29/18 04:59 AM
01/29/18 04:59 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Heaps of thanks, Chrisri.
Fiat GH2 is higher spec'ed. cheers
Re: New Selenia direct injection specific lube [Re: zeng] #4649822
01/29/18 07:37 AM
01/29/18 07:37 AM
Rijeka, EU
chrisri Offline
chrisri  Offline
Rijeka, EU
Cheers2
Re: New Selenia direct injection specific lube [Re: supercity] #4650385
01/29/18 04:28 PM
01/29/18 04:28 PM
Israel
Croc Offline
Croc  Offline
Israel
NOAK is a good catch.
Usually this not stated in oils' specs eek
Locally Selenia Sport costs almost 4 times more than Valvoline and Motul.
I wounder if it's worth it and really would do a better job in the 1.75 tbi engine....
