Originally Posted By: sayjac
Quote:
They look like a good filter but I hate the plastic bypass valve ALL Fram oil filters have.
The Tough Gaurd puts a screen over it, however its plastic and that can become hard and brittle IMO........
...b.c we all know the Honda oil filter is a FRAM Tough Guard.
Fram did away with TG's screen over bypass several years back.
While the Fram made Honda oil filter may look similar in construction to the TG, as has been pointed out here many times, there is a big difference in efficiency between the two.
Wouldn't be the least bit concerned with the durability of the nylon-like bypass material.
According to the Fram manufacturing videos, the "plastic" bypass valve is tested at 500F degrees, if I'm not mistaken.
