2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
43 registered members (carlprop, 928, avacado11, A_User55555, clinebarger, bdcardinal, 1 invisible), 1,089 guests, and 33 spiders.
Topics296,864
Posts4,960,355
Members66,982
Most Online2,688
Jan 19th, 2019
Page 6 of 7 1 5 6 7
Re: Toyota oil filter housing rant [Re: greenjp] #3166382
10/24/13 02:05 PM
10/24/13 02:05 PM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
The first oil change on my wifes 06 Toyota Avalon I used a strap wrench...worked like a charm. The problem is the King Kong types get carried away and then you will need the "$pecial wrench".
Re: Toyota oil filter housing rant [Re: greenjp] #3166400
10/24/13 02:14 PM
10/24/13 02:14 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Originally Posted By: greenjp
Also note in that BMW photo that the filter housing has accomodations for both a special cap wrench (or at least it appears that way) as well as a standard socket, albeit a large one. I've used slip-joint channelocks on my Aunt's old 530.
jeff
Yup, IIRC, it is 24mm. I just use a 1/2" ratchet with the necessary socket on it.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Toyota oil filter housing rant [Re: greenjp] #3166408
10/24/13 02:20 PM
10/24/13 02:20 PM
Texas
Mykl Offline
Mykl  Offline
Texas
If a proprietary, non standard tool is required for the relatively simple task of changing the oil, the manufacturer is doing it wrong.
I would argue the same for transmission fluid.
'10 Volkswagen GTI
'07 Toyota Camry XLE V-6
Re: Toyota oil filter housing rant [Re: supton] #3166424
10/24/13 02:34 PM
10/24/13 02:34 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
Originally Posted By: supton
Good question; no idea. On my VW the filter comes out sopping wet, and I wind up vacuuming out the housing. The oil cooler is right under the filter, and there's a good amount that can get pulled from there.
That's because you only experienced the new version of the cartridge filter, where it has an actual necessary orientation, as it had a solid "dam" area in the center support tube. This prevented from having all of the oil draining back into the sump.
THe older version of that filter did not have that dam, so there was no orientation needed.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Toyota oil filter housing rant [Re: hattaresguy] #3166471
10/24/13 03:37 PM
10/24/13 03:37 PM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
Some of you guys need your "man card" revoked whining about this. Acting like the very minimal extra care to remove skid plates and removing the cartridge filter is going to get your polo shirt and khaki pants dirty.
Jeez, put down your Pumpkin Spiced Latte and get both hands dirty and quit whining it is not like MB or BMW.
2019 Toyota Tacoma 3.5L (Factory Fill 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: Toyota oil filter housing rant [Re: Hootbro] #3166476
10/24/13 03:42 PM
10/24/13 03:42 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Says the guy with three Toyota's wink
Re: Toyota oil filter housing rant [Re: OVERKILL] #3166485
10/24/13 03:47 PM
10/24/13 03:47 PM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
This guy with three Toyota's and three cartridge filter setups, does his own oil changes and does not whine about it.
Re: Toyota oil filter housing rant [Re: Hootbro] #3166490
10/24/13 03:51 PM
10/24/13 03:51 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Well I'm the guy with 2x BMW's that take cartridges and 1x Ford 4x4 with a front diff in the way that takes an FL-820S and who ALSO does his own oil changes and doesn't whine about it wink But it doesn't mean I can't critique what other marques have done to make a change on their vehicles a bigger PITA than it needs to be wink
Re: Toyota oil filter housing rant [Re: Hootbro] #3166492
10/24/13 03:54 PM
10/24/13 03:54 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
wink
Re: Toyota oil filter housing rant [Re: Mykl] #3166515
10/24/13 04:16 PM
10/24/13 04:16 PM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
I have some doozies.
At least for my 2004 WRX, the manual transmission drain bolt had a T-70 Torx head. Hard time finding it back in 2004 and I ended up spending almost $30 on a fancy German made one. It's now pretty easy to find for less than $10. I remember contacting Lisle to ask if they would consider it, and they said they never heard of an application for a T-70. They have one now. It's used on some other stuff, including the front diff in some Subarus.
And when I worked on bicycles, I built my own wheel with a fancy Campagnolo front hub I bought on eBay. It was beautiful polished aluminum but I wanted to rebuild it. It had these unique dust caps and I ended up scratching them trying to remove them with a common tools. Turns out there was a specialty tool just for this particular part. The hub was only a design for a couple of years. I paid a shop $5 just to take it off without scratching it more.
This was the tool to remove the dust cap:
Re: Toyota oil filter housing rant [Re: Hootbro] #3166546
10/24/13 04:44 PM
10/24/13 04:44 PM
CT
hattaresguy Offline
hattaresguy  Offline
CT
I appreciate good designs and point out poor ones regardless of who designs them.
Re: Toyota oil filter housing rant [Re: Hootbro] #3166554
10/24/13 04:50 PM
10/24/13 04:50 PM
Germantown, MD
greenjp Offline OP
greenjp  Offline OP
Germantown, MD
Sure tough guy, come and get it LOL
Re: Toyota oil filter housing rant [Re: hattaresguy] #3166759
10/24/13 07:21 PM
10/24/13 07:21 PM
chicago, Illinois
antiqueshell Offline
chicago, Illinois
Absolutely correct, this is the way it SHOULD BE.
Apologists need not apply.
I am a "fan" of VW products..... HOWEVER I am actually MORE critical of their design and engineering compared to other competing brands because HOPEFULLY consumer input does have an influence on the design of future products.
The companies will not respond to input if the consumer doesn't offer it up, and supplying it in a persistent manner as well is actually the best way to approach manufacturers. the squeaky wheel really does get the oil.
Re: Toyota oil filter housing rant [Re: hattaresguy] #3166846
10/24/13 08:42 PM
10/24/13 08:42 PM
Lake Forest, CA
HTSS_TR Offline
HTSS_TR  Offline
Lake Forest, CA
The splash shield under the Volvo V70 is BIG, hold up by 7-8 bolts. Remove it isn't bad but reinstall is pain in the bud.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Toyota oil filter housing rant [Re: greenjp] #4976444
01/11/19 06:54 PM
01/11/19 06:54 PM
Hawaii, USA
anndel Offline
anndel  Offline
Hawaii, USA
I've been doing changes on our 2005 Toyota Avalon since 2005 and that car came with the cartridge-type filter. I use a 3/8 in drive ratchet to remove the cap and the plastic nipple to drain the filter housing. Then I grab the biggest Channellock I have and remove the housing (by the numerous scratches on the aluminum housing). I just bought a Motivx tool a couple year ago along with the drain hose you screw into the housing to drain it. Yeah a bit more work than the can filters and messier but not a show stopper.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, PP HM 5W-30, Yota OEM Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS5W-30, Yota OEM Filter
Page 6 of 7 1 5 6 7
