Funny oil change moment
by cwilliamsws6 - 08/17/19 10:38 PM
High pitched squeal from new muffler
by Mark72 - 08/17/19 10:19 PM
Delvac super 1300 15w-40 $8.99 TSC
by Capt - 08/17/19 10:01 PM
Flat spotting question
by RyanY - 08/17/19 09:27 PM
Window flashing tape
by spasm3 - 08/17/19 08:27 PM
Amsoil Heavy Duty Metal Protector
by buster - 08/17/19 07:54 PM
Motorcraft FA-4 spec oil
by FlyingTexan - 08/17/19 07:46 PM
Garage clean Just pay shipping or local pickup
by BeerCan - 08/17/19 07:09 PM
200K Miles too many buying a used Honda?
by jayjr1105 - 08/17/19 06:43 PM
Heavy Duty Clutch Kit for 2002 Accord?
by md6040vr6t - 08/17/19 06:33 PM
Frontier - Rear Diff Vent Mod
by buster - 08/17/19 05:59 PM
UOA question(s)
by NavyVet88 - 08/17/19 05:03 PM
Great time at Pirates game
by 53' Stude - 08/17/19 04:29 PM
Post the last movie you watched!
by GumbyJarvis - 08/17/19 03:40 PM
Mobil1 0w16 sale
by HemiBenny - 08/17/19 03:30 PM
Time for some new wiper blades.
by sloinker - 08/17/19 03:08 PM
Mixing Synthetic and Dino Gear oil?
by jrvn - 08/17/19 02:54 PM
Is using your wipers often promotes longevity?
by Vern_in_IL - 08/17/19 02:23 PM
dls56, biskandar, Bob2, Jasonbw1985, Dunnz
68984 Registered Users
54 registered members (bbhero, BuddTX, BeerCan, AdditiveOCD, alchargo, 5 invisible), 1,080 guests, and 23 spiders.
Topics293,443
Posts5,040,308
Members68,984
Most Online3,532
Jul 30th, 2019
Page 2 of 7 1 2 3 7
Re: Toyota oil filter housing rant [Re: greenjp] #3078449 07/27/13 11:22 PM
dishdude Online Content
Online Content
Nothing beats the setup on the 2.2/2.4 GM Ecotec. Right on top of the engine, no special tools and not even a drop of oil when changing the cartridge.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
2019 Tiguan
Re: Toyota oil filter housing rant [Re: greenjp] #3078455 07/27/13 11:30 PM
H
HTSS_TR Offline
H
The cartridge filter housing should be on the top of the engine near the front, like the one in 2000 MB E430. It take less than 60 seconds to remove the filter holder, 1-2 minutes to replace the 4 o-rings and the cartridge filter.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Toyota oil filter housing rant [Re: HTSS_TR] #3078602 07/28/13 08:03 AM
G
greenjp Offline OP
G
Heh, good replies everybody.
Eric, those are great tips I'll be sure to follow next time, thanks. It is ironic that you said "it's not that complicated" and then spell out a procedure that is much, much more complicated than necessary on a normal setup wink The fact that you have to follow a procedure like that to change the filter remains unforgivable bop
Re: Toyota oil filter housing rant [Re: greenjp] #3078604 07/28/13 08:07 AM
E
Eddie Offline
E
Same deal with my Mazda CX7 except I used a $5 cap wrench to remove the canister cap. With practive it is a 10 minute filter change job and no spilled oil. Ed
2014 CX5 Touring 2.5L :-)
Re: Toyota oil filter housing rant [Re: greenjp] #3078781 07/28/13 12:32 PM
T
Tones Offline
T
I agree with Ed, every filter requires the right cap wrench, nothing special there. Its not a complicated change. I like it because there is less waste and no oil makes it to the garbage can. BTW, tightening the cap will not help it seal if it is leaking, there is no additional force put on the o-ring.
'18 Subaru Outback
'11 Toyota Corolla
'10 Honda Civic
'16 Ford F-150 Supercab 2.7TT
Re: Toyota oil filter housing rant [Re: greenjp] #3078783 07/28/13 12:34 PM
supton Offline
Love the setup on my vw, no getting under the car at all. Does not sound like I will like it when it comes time to deal with this on my Toyotas though.
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 153k, ours
1999 Toyota Camry LE, 2.2L/4AT, 209k, his
Re: Toyota oil filter housing rant [Re: pennzoil_guru] #3079320 07/28/13 09:34 PM
L
lenjack Offline
L
Isn't it 64mm?
Any automotive problem can be fixed with a big enough hammer.
Re: Toyota oil filter housing rant [Re: lenjack] #3079510 07/29/13 05:58 AM
J
JethroBodine Offline
J
I get a kick out of threads where people who should never be working on cars try to use all of the wrong tools, never consult a service manual and go attempt even the simplest maintenance unsuccessfully and then flame the manufacturer. LOL
3 minutes on Toyota Nation would have given the OP the necessary information. You can get an Assenmacher filter cartridge tool on Amazon. Then if you purchase the factory filter element you get the plastic adapter that allows you to drain the cartridge before unscrewing it.
This is all spelled out with pictures in the factory service manual and probably the vehicle owners manual.
Re: Toyota oil filter housing rant [Re: greenjp] #3079525 07/29/13 06:18 AM
supton Offline
Oh come now. What's the point of using a filter element that can only be gotten to under the vehicle?
I just checked on my Tundra, and it does not spell out how to change the engine oil, just how to check it. Same cartridge setup. I'm not entirely sure that one should be required to obtain a service manual in order to change the oil. That seems just a bit over the top, don't you think?
What's more asisine is Toyota's method for checking ATF level in their WS transmissions...
To be fair, it's not even the OP's vehicle, he was doing a favor for the MIL.
Re: Toyota oil filter housing rant [Re: lenjack] #3079538 07/29/13 06:49 AM
ChiTDI Offline
Originally Posted By: lenjack
Isn't it 64mm?
Yes it is.
A 65mm (more common in the toolbox) will work, just adapt for the extra mm. Turn the cap slightly at an angle, put a small piece of sandpaper between the filter and socket, etc...
Re: Toyota oil filter housing rant [Re: ChiTDI] #3079546 07/29/13 07:07 AM
T
The_Eric Offline
T
Isn't it 64mm?
Yes it is.
Yep.. I was mistaken on that one. 65mm X 14 flute.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Toyota oil filter housing rant [Re: greenjp] #3079550 07/29/13 07:15 AM
K
Kruse Offline
K
Originally Posted By: greenjp
So to whatever fool(s) at Toyota thought up this thing, go to [censored] shoot
ha ha.
Look on the bright side. It could have been a Toyota pickup where you had to remove a belly pan to get to the same filter.
Re: Toyota oil filter housing rant [Re: supton] #3079569 07/29/13 07:42 AM
J
J
You mean like 90% of the vehicles out there? Like I said. I get a kick out of people who should never be working on cars and then think it is "unfair" when they have to get the proper tools for the job. However, most all trades require specialized tools. Plus, checking the ATF level on a Toyota trans is simple...if you have the correct tools and know what you are doing.
Re: Toyota oil filter housing rant [Re: greenjp] #3079572 07/29/13 07:45 AM
J
J
Here is the "mystery tool"
http://www.amazon.com/dp/B0015PK3AG
LOL
Re: Toyota oil filter housing rant [Re: JethroBodine] #3079592 07/29/13 08:12 AM
supton Offline
What can I say? The last 9 years I've been doing top-side oil changes on my VW. Once I started doing that, I've dreaded going back to having to crawl in the dirt.
Is checking the level that simple? Been a week or two since I read the proceedure. Off the top of my head:
-jumper two pins on the OBDII port together *OR* get a scan tool to monitor ATF temp.
-when the ATF is at 115F or thereabouts, and as long as the temperature is within a 7 degree F window (otherwise, let engine idle or cool until w/in this window):
-crawl under vehicle, remove check level bolt
-if the oil drips out, it is too low
-if it streams out, it is too high
-if the flow coming out is just right, then all is good.
-if you need to add oil, go find a hand pump to add via the fill hole, or find a tube to snake up into the engine bay, and of course watch out for hot exhaust.
I understand why Toyota did away with the dipstick, but that doesn't mean I agree with their decision to do so. Would any of us agree to no longer have an engine oil dipstick?
Page 2 of 7 1 2 3 7
