Originally Posted By: Trav
You cooked it. A 2A charger with no controller will put 96A into the battery in 48 hrs.
Your battery is probably around 50A.
I don't understand the calculation to figure CCA charging rates so i don't bother with it, i just need to know how many amps the battery has.
Look at this German site. Notice the first number is the amps of the battery, if you know the amps you know how long you can charge it at a given charger output.
Big MB diesels use a 74 -95 amp battery. A 27f is around 50A IIRC.
A 50A battery can be charged to 100% at 5A in 10 hrs, 10A in 5, or 2A in 25 hrs.
When no info is available you can use the 50A figure for most mid sized and 75A for large automotive batteries, if it doesn't charge it to 100% it will be close and start the engine.
Sorry for over simplified answer but this is the easiest way i can explain it.
http://www.atu.de/shop/kategorie/Batterien-w5722/Auto-Batterien_w5723/
Lead acid battery cycles are NOT 100 % efficient, it takes MORE than 10 amps for an hour, for example, to fully charge a 10 amp-HOUR battery. Probably more like 12 to 15 amps for an HOUR. The rest ends up as heat. The accurate test of a storage battery is how many amps it will deliver for an hour... "amp hours". Interestingly, the figure changes a bit as rrelated to discharge level, a 70 amps for an HOUR battery might give you 35 amps for 2.25 hours. With use, a battery takes more and more "amp hours" to fully charge, and more and more of the supplied current turns into heat until one day, the battery won't charge at all. Numbers like "cold cranking amps" relate to very short periods of use in cold weather when the chemical reaction is slowed, "just when you need it the most". Even a flashlight battery will output 100 amps for a small fraction of a second. "Deep cycle" trolling motor batteries are this that, designed for a slow discharge rate for long periods. Modern sealed batteries not of the deep cycle type are often damaged by being run doen to the no charge left state. It appears that "AGM batteries, a newer type of sealed battery, isn't as subject to such damage. As for Ni Cad, NMH and "LiIon type "electronic unit" batteries, they are all different in performance. Many "fast chargers" for electronic and portable tool batteries have a "thermister" built into the battery case with a lead for a charger connection, the internal temp of the battery pack is measured to so that the charger output can be controlled to prevent heat damage to the battery.
