A Joe Gibbs oil formulated specifically for GM LS-series engines that get a lot of track use.
From Polaris Labs
Wear Metals
Should be low for a virgin oil, only 1 ppm each of Iron and Aluminum.
Contaminant Metals
Si: 4 ppm
Na: 3
Multi-Source Metals
None. No Ti, Mo, or B, which are additive metals we've all gotten used to seeing lately.
Additive Metals
Mg: 151
Ca: 2435
P: 983
Zn: 1135
KV100 = 10.9 Cst
TBN = 10.1
Oxidation = 10
Nitration = 5
I'm surprised at how simple the additive package looks.
With ~1000 ppm of Phos, it would qualify as an SL oil.
The main reason I replaced Red Line 5w30 with the Joe Gibbs LS30 was the higher TBN.
From Polaris Labs
Wear Metals
Contaminant Metals
Si: 4 ppm
Na: 3
Multi-Source Metals
Additive Metals
Mg: 151
Ca: 2435
P: 983
Zn: 1135
KV100 = 10.9 Cst
TBN = 10.1
Oxidation = 10
Nitration = 5
