You have a couple of options here and still be within the warranty specs. First, is the old standard of 30wt, but not the best choice. Not there's anything wrong with using 30wt, as there's been years and years of mowers run on it. But if you want the best, then go for 5w30 syn. I would not just use any syn 5w30, even though it woulf probably be fine, but I would use a High Mileage oil, as it has more Zddp, which is good for air cooled small engines. I use Mobil 1 HM 5w30 in mine, it has a bit higher Zddp level, than normal pcmo oil. I don't know what the zddp level in PZ Ultra is, but it's one fine oil. Don't let anyone talk you into the "heavier is better" myth for these engines until you've tried what's recommended. Thinner will cool better, multi-vis will protect at startup and syn will shear far less.
