"...........Pirelli claims the innovation—being pitched as "Pirelli Noise Cancelling System"—can reduce the noise heard by those inside the car by 2 to 3 decibels, or roughly half.
With this development, Pirelli is addressing noise caused by the vibration produced when air inside the tire is compressed as the tire is squashed against the road. This noise is transmitted from the tire to the wheel hub and eventually reaches the inside of the car's cabin via the steering and suspension components.
The polyurethane foam sponge is designed to absorb these vibrations, the tire maker said, and thus reduce the amount of noise passed through to the cabin..........."
http://www.tirebusiness.com/article/2013...-with-pu-sponge
I could use a set of these on my Subaru!
