0W30 with MB 229.52 and VW 507 for Canadians
by Snagglefoot - 11/20/19 10:12 PM
Need new Binoculars
by FirstNissan - 11/20/19 09:47 PM
Fram Extra Guard now rated to 10k miles
by addyguy - 11/20/19 08:47 PM
HF Mechanic's Cart Coupon
by TheLawnRanger - 11/20/19 08:45 PM
Factory Fill 2019 VW Jetta 1.4t
by DuckRyder - 11/20/19 08:12 PM
Castrol Edge Professional LL IV FE 0W/20 (VW508)
by DuckRyder - 11/20/19 08:08 PM
2019 Kia Sedona - Oil Filter Housing
by XpressAuto - 11/20/19 07:46 PM
Belt/ Tensioner wear
by bruckus - 11/20/19 07:42 PM
Eneos CVT fluid
by bbhero - 11/20/19 07:38 PM
Game changer?
by P10crew - 11/20/19 07:34 PM
Permatex Brake Lubricant
by Snagglefoot - 11/20/19 07:01 PM
2015 BMW 328i Pennzoil Platinum 5w40 Euro
by TurboJW - 11/20/19 06:55 PM
STP S2808 (Blue) now also a H/K clone
by wemay - 11/20/19 06:30 PM
New to shortwave radio
by cwilliamsws6 - 11/20/19 06:22 PM
Ford Tempo
by Eric Smith - 11/20/19 05:40 PM
quick FL-910s C&P
by BeerCan - 11/20/19 04:50 PM
Adding keyless entry to an older car
by atikovi - 11/20/19 04:36 PM
blind spot monitoring sensor 2017 jetta
by raaizin - 11/20/19 04:33 PM
Subaru Forester rear brakes
by Donald - 11/20/19 04:19 PM
ImBoosted, XpressAuto, Jmpage388, baileyclarke, Jbloggs
69924 Registered Users
80 registered members (69Torino, 69GTX, 2004tdigls, 4WD, 2010Civic, 6 invisible), 1,441 guests, and 26 spiders.
Topics297,700
Posts5,120,942
Members69,924
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: 2005 GMC PCV Valve 5.3L [Re: Wingman] #2944321 03/19/13 03:25 PM
X
xxch4osxx Offline
X
Any pics?
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: 2005 GMC PCV Valve 5.3L [Re: The_Jake] #2944701 03/19/13 08:37 PM
O
OtisBlkR1 Offline
O
Originally Posted By: The_Jake
If it is slipping out try some gorilla glue on it and allow to dry overnight in your garage. Don't use too much as that stuff expands 3x.
what are you talking about ????? glue ??? this truck has a non-removeable PCV setup.
06 Silverado 92,xxx Mobil 5-30
11 Honda Accord 38,xxx Mobil 1
06 Milan 69,000 Mobil 1
12 Ranger 800XP & 14 TRX 450R
Re: 2005 GMC PCV Valve 5.3L [Re: Wingman] #3049231 06/29/13 08:46 AM
T
TiredTrucker Offline
T
The AFM (automated fuel management) setup on many GM engines that causes the engine to go to 4 cylinder mode when less power is needed has caused a plethora of oil consumption problems. Supposedly, this problem got resolved with the late 2011 engines on, but time will tell. Many, like me, have effectively disabled the AFM from ever going to 4 cylinders. The engine remains in 8 cylinder mode all the time.
Now, to the oil problem getting into the intake from the PCV system. Simple. Most, if not all, folks should consider installing an oil catch can in the PCV line from the PCV valve/fitting and the intake manifold. This will filter out any oil that normally is drawn up with the crankcase gasses. This oil can reduce power, in that the ECM has to compensate and sometimes resort to low octane settings in the ECM. Also, this oil will coat the inside of intake manifold, add the EGR exhaust gasses coming in, and you have a recipe for serious crud. And some of this will coat throttle bodies and valves.
All in all, just a bad situation just waiting to happen. These oil separators are relatively inexpensive and not difficult to plumb into the PCV line. I just purchased a 2013 Silverado with 5.3L and an oil separator will be going on within the next few weeks.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Page 2 of 2 1 2
