I need help in figuring out how to drain the radiator in newer GM 2.2L and 2.4L vehicle radiators. There is no traditional drain cock in the newer GM's. At the bottom left side there is a quarter sized plug like device with a "+" like slot. My question is: which way to turn this plug and what kind of tool works best? I understand that this plug does not come out, but just turns enough to open the drain.
I'd like to hear from those of you who have opened and closed this kind of valve before I give it a try. I'd rather NOT remove the lower hose, etc. TIA!
