Originally Posted By: Clevy
Originally Posted By: CATERHAM
Garak, I didn't notice this before but that's one heavy oil you're running in the G37.
Using a synthetic is against my religion already. Now you want me to mix oil? Are you trying to kill me?
I could have had heavier and conventional and just asked for the 15w-40 back from my buddy. Really, though, the Delvac 1 was just orphaned from my stash, so I tossed it in the G. Yeah, it's pretty heavy, but I don't think it's seriously out of line, given the rather high oil temperatures of the engine (significantly higher than that of the Audi 200 Turbo).
As I use the Delvac 1, I'm going to see what I can do to push out these OCIs, if I can resolve to be brave enough (and do some UOAs, of course). The lube choice of Delvac 1 and extended intervals work for Doug; I'll see if it will work for me.
If I'm thinking things are too heavy, I'm not afraid to try the Delvac Elite 222 0w-30. Imperial Oil's regular pricing on synthetics rivals Walmart's regular prices on conventional.
If I chicken out in the end, I won't be running to the Toyota dealership to do a blend, either. I'd be too freaked out and have to return to my PYB. Nonetheless, before that would happen, we'd have to restore balance to the oil universe. I'd have to put in a good word with an Ontario Imperial Oil distributor for Overkill so he can get his M1 0w-40 at a more sensible price, and I'll have to introduce myself to the SOPUS distributor here. The last time I dealt with one of them was long before Quaker State and Pennzoil joined in.
I will concede that choosing an oil is a religious experience for some.
Yes if you could bring yourself to consider the Delvac Elite 222 0W-30, (a true PAO syn') it would be a much more suitable choice.
Or even better, PC Duron 0W-30, it's lighter still (HTHSV 3.33cP) and is only a GP III syn'?
I appreciate the bottom line is price (that's the true religion), but running these heavy dino's is IMO false economy....think about it.
Hey Garak. Have you ever looked into the Co-op branded oils. They are bottled by esso so Mobil basically.
The one oil they sell that I've been really considering the the syn 0w-40. It has an insane pour point of -67 or something and its an sm rated hdeo. I did some research and its strikingly similar to the devlac-222 0w-30 and its got PAO stamped on the top corner of the label. I've found it on co-op shelves for 24 bucks a gallon locally and I'm sure a guy could buy 5 gallon pails of the stuff and get an even larger cut as far as cost is concerned.
I brought this oil to Caterham's attention because I thought it might be one of those sleeper oils,a diamond in the rough so to speak,and the price puts it into near rollback Walmart prices for synthetic oils and cheaper than conventional jugs at full price however the co-op oil is only a gallon vs the 5 quarts found in the rollback jugs.
Check it out. The Co-op website has limited info on the oil itself and you will likely be able to translate what all the numbers mean,which in all honesty would help me figure out if its a good value for the price vs Walmart.
And I really like the idea of 5 gallon pails. If I could get it in the 80-90 dollar range for 5 gallons that puts it in to the good value column for me.
And it advertises very high pao content. Like more than we as bitoger s may feel comfortable with due to the group 4 base additive solubility issue. Or is that also been solved?
Maybe I'll pm molakule and ask for his thoughts on it. At 6 bucks a litre its half the price of M1 and that pour point just amazes me. Its hard for me to fathom a 40 grade oil to be anything more than a solid block at temps that cold,so our -40 temps would nothing for that oil so cold starts would be a complete non issue.
And my forklift would pull way less amps at start up in winter,as well as less wear on the started mechanism in general,and just how much faster that oil will flow on those -40 morning starts makes me feel all warm and fuzzy inside.
I'll pm Molekule and ask what he thinks of it based on the limited info posted by co-op.
I'll see if I can glean any insight from him.
Clevy, here's the PDS on the CO-OP 0W-40:
http://www.rrcoop.com/prod_dmo_gold_sl.html
The PP is "only" -57C and no MRV, CCS or HTHSV spec's are provided. The ZDDP is very low for a diesel oil.
But a VI of only 150 for a 0W-40 is pathetic.
Sorry but I'd pass on this oil.
