Originally Posted By: SOHCman
True, if you use a bunch of fuel it doesn't make sense except for maybe a "last fill" of the season, and use the cheap fuel before that. That way it's not stored with ethanol, and you have the best of both worlds.
Not sure I'd even say that. I've been using Stabil and MMO in the fuel mix for the last 2 years and storing things wet. Knock on wood, no issues here so far. I rotate my non 2-stroke gas storage every 6 months, once in the spring and once in the fall.
Blower, which is 2006, I replaced fuel lines this year and it still runs well and it's been run on some pretty old and crummy 2 stroke mix. Even ran it on gas + Rotella mix when I ran out of 2 stroke mix. Runs fine.
Weedwhacker, 2010 stored wet always runs fine.
Mower, 2008 stored wet starts fine.
Pressurewasher, 2011 same deal.
Generator - 2011, I alternate when I excercise it - sometimes run it dry sometimes I store wet.
Snowblower - this one I had issues with as I used to store it outside in the rain/snow during the winter at the old house. Replaced the carb this year and stored dry after a liberal application of WD 40.
