Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
102 registered members (65convertible, Ablebody, Balrog006, Astro14, Al, 7 invisible), 1,703 guests, and 44 spiders.
Topics290,762
Posts4,849,857
Members66,034
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Toyota 2AZ-FE oil burn #3023340
06/05/13 03:25 AM
06/05/13 03:25 AM
CA, United States
535678 Offline OP
535678  Offline OP
CA, United States
This seems to be a common problem for those with Toyota 2AZ-FE (4 cylinder, 2.4L) engines. At higher mileages, oil burn suddenly increases. I first noticed this about a year ago when I checked the dipstick and found the oil barely discernible on the low end of the stick. This never happened previously in such a short period.
Ever since I've kept careful notes. All fills listed below were with Mobil 1 HM 5W-30.
05-17-2012 -- 96987 miles -- drained 2.9 qts -- replaced Purolator filter, filled with 4.0 qts
09-02-2012 -- 99219 miles -- dipstick low, added 0.5 quarts
11-25-2012 -- 101550 miles -- dipstick low, added 0.3 quarts
06-04-2013 -- 105970 miles -- drained 3.2 qts -- replaced Purolator filter, filled with 4.0 qts
How much oil are we supposed to get with a drain and filter change, the full 4.0 quarts?
If yes this means it burned 1.6 quarts over the previous 8983 miles...roughly .178 quarts per 1000 miles.
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023342
06/05/13 03:52 AM
06/05/13 03:52 AM
California
Voltmaster Offline
Voltmaster  Offline
California
whats the mileage ?
Re: Toyota 2AZ-FE oil burn [Re: Voltmaster] #3023344
06/05/13 03:55 AM
06/05/13 03:55 AM
CA, United States
535678 Offline OP
535678  Offline OP
CA, United States
Originally Posted By: Voltmaster
whats the mileage ?
Read above.
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023367
06/05/13 05:11 AM
06/05/13 05:11 AM
Mid Atlantic
229 Offline
229  Offline
Mid Atlantic
Is it leaking oil around the head gasket or losing coolant?
This engine series has a problem with the head bolt threads pulling out of the block.
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023376
06/05/13 05:42 AM
06/05/13 05:42 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Capacity with filter is 4qts. Cant be exact measuring with a dipstick. All oil doesn't come out whether its been sitting 5 mins or 5 hours. Oil remains absorbed in the filter media. Use 1qt every 5k. Close enough.
You say suddenly. Is that why you switched to M1 HM? How long have you been using M1 HM? What oil was used prior? What year is the engine? Different years, different problems.
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023389
06/05/13 06:03 AM
06/05/13 06:03 AM
CA, United States
535678 Offline OP
535678  Offline OP
CA, United States
I was under the impression Purolator PureONE filters do not absorb as much oil. Whenever I change mine, I turn them upside down on the drain pan for several hours to let them drain.
2004 model engine 2AZ-FE
For this drain I jacked up the left front (as if I was changing a tire) and got another 0.2 quarts drained that way.
Been using synthetics exclusively for the last 50K miles. Used PP for a while, then regular M1 synthetic. No reason other than the odometer reading for switching to M1 HM the last two oil changes.
Yes, suddenly in the sense consumption increased dramatically around 90K. Reading the Toyota forums, this seems to be quite common...the consumption problems for many begin at 80K-100K miles. In my case, it was burning at most 0.3-0.5 quarts every 5000 miles up until 90K miles.
No coolant loss. No head gasket leaks. No leaks out the bottom.
I realize the consumption I'm seeing is nowhere near as bad as others are seeing. My question is whether to expect consumption to keep increasing or will it somewhat stabilize for a while? On a side note, I should probably replace the PCV valve as that's never been done on this engine.
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023391
06/05/13 06:05 AM
06/05/13 06:05 AM
CA, United States
535678 Offline OP
535678  Offline OP
CA, United States
On another side note, I did take an oil sample, so I'll be sending it off to Blackstone for analysis.
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023408
06/05/13 06:41 AM
06/05/13 06:41 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I don't drain for long periods for every last drop so I don't know exactly how much comes out. Want to avoid dry starts, when most engine wear occurs.
Your going 10k a year, assume local car. Not much heat, should be ok with the stripped thread issue. Drain and fill the coolant if you haven't.
The main oil consumption issues in that year are the valve seals or clogged piston oil return holes. By now, M1 HM has done all it can do for seals. In this engine, a 1 second small puff of blue smoke can be noticed at the tailpipe on a morning start only. It happens fast, will only be noticed if your behind the car when it starts. Have somebody else start it in the morning and watch. if you see the blue puff, have the valve seals replaced.
The piston oil return hole clogging is cumulative from day 1. So its more what happened early in the cars life, not necessarily recent. Because of location, flow, and depth of deposits in the holes, near impossible to remove unless caught early. You can try solvents, but IMO only answer is teardown. Expensive. IMO not worth it.
PCV may help, use an OE only.
Can't say it won't get worse, but mine hasn't in well over 100k. I burn more than you, but M1 HM made consumption lessen over 2 OCI's. Because in my case the valve seals are bad. The cost of repair is not justified in this car so I'm living with it. Burning 1 qt every 3500-4k.
Lastly, not all oil consumption is bad. You get a chance to replenish, which means you can extend the interval longer. Using M1 HM, 1 year/10k is fine. Personal opinion, use a high efficiency extended interval synthetic media oil filter rather than a resin/paper media filter. Better flow longer.
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023419
06/05/13 07:03 AM
06/05/13 07:03 AM
SunnySouthFlorida
KitaCam Offline
KitaCam  Offline
SunnySouthFlorida
OP:
When changing the PCV valve, check the hose...mine was brittle-hard/cracked at each end and needed replacing too ($15 @ dealer)...
I got my 2AZ-FE @97.5K and with PYB 5w-30 it had dropped to 1/3qt down after 3k miles when I switched to PP 5w-30 @ 103k...when I changed plugs, PCV valve/hose, valve cover gasket...
I'd feel your concern too for a loss/burn increase from .5qt/5k miles to .5qt/2500 miles....with PP mine's only bit better @ .5qt/3-3.5k miles....but...
The loss/burn off RATE MAY LESSEN between half-way down to the "L" line and the "L"...at least that's what I've read others have experienced...so what I'm going to do monitor the dipstick and see just how many miles it takes to get to "L"...when it'll get the next OC...this is only my 2nd OCI (the engine's first with synthetic) so I'm not sure what to expect...
I know this is too simple, given your your attention to detail, but since didn't mention it...when you did fill up, was the oil AT the "F" line?...and...
Has you driving changed at all...like more highway miles?
Kitacam is an 05 Camry LE/I4/MT; latest OC: 2/17 @ 142,300....PP 5w-30 with Toyo filter
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023421
06/05/13 07:06 AM
06/05/13 07:06 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Also if you have no external gasket leaks... In your climate I would try M1 0w40. A thicker operating weight will slow consumption in both areas discussed. Sold in the walmart jug now! Currently on rollback at $22.47 / 5qt jug
If you want to blend M1 HM 5w30 with M1 HM 10w40 thats fine too. Top off with a quart of M1 HM 10w40, see what that does.
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023473
06/05/13 08:11 AM
06/05/13 08:11 AM
North Coast
Doog Offline
Doog  Offline
North Coast
I have one that is not burning yet but am only at 80k miles. However, it has had synthetic with 5k oil changes since new. But it is a common issue with this engine for certain years. I have one of the ones that requires a tear down to replace the rings to fix it. This will never happen as long as I own it. So, I keep using any synthetic. My neighbor has one and he changes oil every 5000 and just puts 4.5 quarts in and uses the .5 quart in 5000.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..Coffee2
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023539
06/05/13 10:03 AM
06/05/13 10:03 AM
western ny, usa
ronbo Offline
ronbo  Offline
western ny, usa
NOTE: the PVC value is called a ventilation valve in the RAV4.
I have the mentioned engine and I too noted an oil use increase at about 90,000 miles. (108,000 miles now). I known for a while that I need to check my "PVC" valve.
Re: Toyota 2AZ-FE oil burn [Re: 535678] #3023567
06/05/13 10:33 AM
06/05/13 10:33 AM
SunnySouthFlorida
KitaCam Offline
KitaCam  Offline
SunnySouthFlorida
Yes, Ron...PCV = Positive Crankcase Ventilation
Re: Toyota 2AZ-FE oil burn [Re: LeakySeals] #3023765
06/05/13 02:43 PM
06/05/13 02:43 PM
CA, United States
535678 Offline OP
535678  Offline OP
CA, United States
I'll inspect for blue smoke in the morning. Good tip, thanks!
The car has had 66% city (25-50 MPH stop and go) and 33% freeway (no more than 65-70 MPH around here) its whole life. The overwhelming majority of the driving has been thirty to forty minutes commuting to and from work, approx 35 miles per day. We don't drive our cars rough, if anything we're light footed to save gas.
I've read about the piston oil return hole clogging on the Toyota forums. In fact, I think I read comments made by you on this very topic. This is really frustrating, especially on a Toyota product. It's a great car in every other respect. I hate the idea of having to sell or junk it prematurely because it needs an engine rebuild.
I thought Purolator PureONE were considered high efficiency/extended interval with synthetic media?
Re: Toyota 2AZ-FE oil burn [Re: KitaCam] #3023781
06/05/13 03:01 PM
06/05/13 03:01 PM
CA, United States
535678 Offline OP
535678  Offline OP
CA, United States
Originally Posted By: KitaCam
OP:
Thanks for the tip!
The problem for me is that the ladies in the family drive the RAV4 far more often than I do. They're not as mechanically inclined to check the oil level and add oil on their own. The burden is on me to keep track of these things.
If the oil consumption gets much worse, I see this being really problematic when they want to take it on road trips. And even if I could teach them how to fill the oil, this is something they will completely forget about until they get home. I hate to stereotype all women like this, but every woman I've known has been terribly naive in this department.
Yes, I've been refilling up to the F line on the dipstick.
Driving has been the same over the life of the car. Mostly city, some freeway locally, and the remaining freeway has been road trips.
Page 1 of 3 1 2 3
