Originally Posted By: Clevy
Originally Posted By: CATERHAM
A BMW S1000RR 193hp bike engine.
What I found interesting was the amount the valves and valve springs spun around at maximum rev's. The valves were floating, perhaps only to a slight extent but floating nonetheless.
I saw that too. Its at the point where the cams actually look as though they begin spinning the other way.
I saw the smoke and instantly thought that maybe an oil with a lower noack would vaporize less.
This bitog is a sickness
I've experienced valve float in in some modified cars I've had in the past; that's one of the factors that limit how high you can rev' an engine and heavier valve springs to solve the problem is counter-productive at lower rev's.
14,000 rpm may be about the rev' limit for metal valve springs.
F1 engine that rev' to 18,000 rpm use pneumatic (air) springs.
A lower NOACK rated oil isn't going to noticeably reduce the oil "vaporizing". I think what you're seeing is the oil being very finely atomized. The spec' oil is a 4T 10W-40 with a typical NOACK of 10%.
The other thing is, the camshafts rotate at half crankshaft speed. So what we're observing is "only" 7,000 rpm.
