88' GMC Suburban 350 5.7L
Does anyone know how much coolant these hold?
I have a kinda interesting leak...When the car sits for a few days it will slowly leak about half a gallon of coolant(I only use water currently). The leak is on the driver's side of the engine and drips onto the oil cooler hoses and then onto the cross-bar between the front wheels. I don't know exactly where it is dripping from onto the oil cooler line. I need to go under there again and maybe use a mirror to see. Can't see much normally.
The Coolant does not leak while I'm driving. However it will start to drip about five minutes after I stop somewhere.
I've had a few suggestions that the problem may be bad/going freeze plugs. I'm not sure where these are though. It is hard for me to see anything on the bottom of the engine when I'm under there.
Are there any specific lines or connections on the driver's side of the engine I could check to see if they're the ones leaking?
Also(once I get this leak fixed) since I'm in GA, what mix of Anti-freeze/water should I do? 50/50?
Thanks
Thanks
