Picked up a 2007 Sienna XLE AWD with 141,000 miles that has the original transmission fluid (World Standard). The servicing dealer's stance is to not change fluid unless there is a problem with the transmission. Fluid is very dark at this point.
I'd like to keep this van on the road as long as possible (no indications of transmission slipping, clunking, etc. yet).
What would you recommend for servicing the transmission at this point? Should I do drain and fills in short intervals until the color improves or have a shop flush the transmission completely? Should I install a trans cooler (not planning to tow)? Any recommendation for fluid change intervals going forward?
I saw the other current thread about trans fluid for a Sienna that is towing. I'm not sure if I'll go with Amsoil or WS fluid, but there's good info in that thread already.
