With the amount of rust the Escape has! Rust sure is a sneaky creature. I typically rinse the underneath every time it's washed even in the winter, perhaps wash it too much? A couple years ago for 2 straight years I sprayed some old oil but it got to messy to continue. This isn't the only rust either. Floor pans up front, the wheel wells in the rear completely rusted through.. that was well hidden.
The back story is build date is 9/03 and we bought it in 06 with 36k. Not sure if PO's non treatment had anything to do with it. This vehicle is typically driven in bad weather versus our others. The Focus has hardly any rust. It did set on the street till we got a driveway and they use a sand/salt mixture that's still on the road today.
For right now I took a wire brush and sprayed some rust converter on it. When I get back from our trip to Cali planning on getting a wire wheel for the angle grinder and retreating with rust converter (not sure how much that helps) and after some rustoleum. So much for driving it till it dies.. may rust in half first!
