Post your latest upgrade
HTPC from the i3-2120 that vacated the other computer
coolermaster elite 311 case
ASRock H61M/U3S3
coolermaster Gemin II M4
microcenter 2x4 GB DDR3-1333 MHz
samsung 60 GB SSD 830
antec tricool blue 120mm
corsair SP120 quiet edition
still need to get 3TB HD...
May I suggest a better camera as your next upgrade?
wanna buy me an iPhone 5 to replace my 3GS?
-From 8GB Mushkin Redline DDR3-1866 RAM, to 24GB of Mushkin Redline DDR3-1866 RAM
-From 64GB Crucial m4 SSD to 256GB Crucial m4 SSD
-Added ASUS Xonar DGX PCIe Soundcard
I put an iStarUSA trayless hard drive cage in. I connected it to the second SAS connector on my Adaptec 6805 with a SAS to SATA fanout cable. I did install my spare Samsung F3R 1TB in the top slot as a hot spare for my RAID 5.
For the second array, Im looking at a pair of Toshiba MG03ACA 3TB drives in RAID 1. That will be my bulk storage then. Ill probably Move all my data off the RAID 5 to it and reconfigure the Samsung F3Rs into a RAID 10 for fast primary storage. As I need more space Ill add more Toshiba's and convert it to RAID 5, first with three drives for "6TB" then 4 drives for "9TB".
Both upgrades were on my Dell Optiplex 760 MT (w/ Intel Core 2 Duo 8400) that is my HTPC
- Fresh install to 64bit W7 Home Premium from 32-bit W7 HP
- 8GB DDR2 PC6400 RAM coming from 2GB
- Fanless Sapphire Radeon HD 5450 1GB card ($20 after MIR!) coming from Intel Integrated Graphics.
A couple weeks ago I combined 2 IBM Thinkpads into 1 fully working unit. In the process, I upgraded from a Celeron 550MHz CPU to a Pentium 3 rocking at 900MHz. Aw yeah.
Purchased and installed my Toshiba MG03ACA 3TB drives. I had them in the bay, setup as RAID 1, formatted, and had my data copying over within 3 minutes of unboxing.
These things are wicked fast.
Instead of doing what I thought I was going to do, I did a Migration of my RAID 5 to RAID 5EE, using all five of my Samsung F3R 1TB drives. RAID 5EE is N-2 like R6, but keeps the single parity of R5. It spreads the data out across all the drives so if a failure occurs, it compresses the data back to a normal N-1 situation. Theoretically higher throughput and IOPS since you have more spindles working. I dont know if I would use it over a RAID 6 in a more critical environment. If you have a failure, it has to compress the data to normal R5, then when you replace the drive expand it back out. Very IO intensive on both sides. But, I have back ups and I like to live dangerously.
Added the Cache protection module to my 6805.
Pretty neat. The daughter card has 4GB NAND flash. During a power failure, the cache memory is copied to the flash, using the supercapacitor to keep the cache hot and support the copy operation.
I upgraded my brothers computer recently.
Antec 300
Phenom II X4 965BE OC 3.82Ghz cooled with a new CoolerMaster Hyper 212+ Evo
8GB Corsair DDR3-1333
XFX Radeon HD 7770
Sandisk Ultra 120GB SSD/WD 500GB Blue HDD
Antec Neo Eco 400C PSU
ASUS M4A88TD-V EVO/USB3 Mobo
Gateway 20" LED-LCD Monitor
Microsoft Sidewinder X4 KB/Razer NAGA Mouse
I didn't comment on it before but awesome rainbow dash plushie
Are you talking about the Hot Topic vinyl figure, or my actual plush?
Some nice looking rigs in here. I have no touched mine in a year or so. Still working great with my last upgrades, no intention of changing anything until at least fall.
OK, you guys are weird, LOL!
Pffff.
Dont knock it 'till you try it.
On topic:
D: and E: are on the Samsungs and F: is on the Toshibas.
Replaced my router:
Out:
PC P&C Silencer II 420W (80+)
DFI NFII-Ultra (upgraded capacitors)
AMD Athlon XP-M 2400+ 1.8GHz (@2.4GHz) 35W Socket A [Barton]
2x 512MB GEIL DDR-400
ATi Radeon 9600 SE
2x Intel Pro/100 ethernet
Seagate Barracuda 7200.10 80GB IDE
Samsung Spinpoint 40GB IDE
10X DVD-ROM
Hardened Gentoo Linux x86
In:
Antec ISK110 case
90W Delta 19V power brick + internal DC-DC 85W supply
MSI Fuzzy RS690T (improved cooling)
AMD Athlon X2 4450B 2.3GHz 45W Socket AM2 [Brisbane]
2x 2GB hynix DDR2-667 SO-DIMM
Onboard video from AMD 690 chipset
2x Marvell 10/100/1000 NIC (onboard)
Fujitsu 120GB 5400RPM 2.5" HDD
Hardened Gentoo Linux x86_64
I built this with an SSD, a 64GB Crucial M225, but it was old when I started and failed shortly after being pressed into actual service (I stress tested the machine for several months prior to use to verify stability). I ended up scavenging a 120GB Fujitsu from an Xbox 360. I wanted to stay SSD, primarily because I am concerned the heat inside this TIGHT case will cook the HDD alive. But, I can't afford one. I still have the old machine, but I would really rather stay with this one, if I can.
Pulls 32 watts idle and 74 watts full load. The old machine was pulling 71 watts/152watts. So, 45% idle power and 49% full load. Thats what I was aiming for was to cut power draw in half. It does that and I get an extra core out of the deal. Then, they are faster to start with.
Thankfully this one appears to be fine, lol
Gigabyte Geforce GTX 760/2GB (oc 1130 Core/1280 Boost) "windforce" (this card is loooonnnnnggg)
EDIT: Oh yeah, and I added a Western Digital 1TB Black too. lol
Which gives me.... A lot of storage :p Not counting the extra 2TB I added to my NAS.
