So, I've been noticing lately that my gas mileage has been on a steady decline for the past couple of years and it's now just starting to bug me. I know that the primary O2 sensors are the main piece of hardware that controls the A/F mixture when in closed loop, so my question is would an oil burning incident from 3 or 4 years ago damage the sensors enough that they have not been functioning correctly all this time and I'm just taking notice?
The PCV system in the Audi is prone to freezing in really cold weather, and one winter probably 4 years ago it froze solid and in the 6 miles between my house and my friend's where the car was parked I went through 1.5 liters of oil. Had the flashing CEL for massive misfires, the big cloud of smoke behind the car, and reduced power. Once the car sat in the garage, it defrosted and ran just fine after a new set of plugs. I just don't know if the episode killed the O2s right then and there, or did it start the slow death of them? The car probably had 90k miles on it at the time, and it's at 150k now. Maybe it's just time to replace them anyhow at this mileage?
I've watched them with my scanner, and they seem to be functioning as they bounce around in the voltage range from about .05v to .75v. I don't know what the correct readings should be.
