Carbon Farming
by SubLGT - 12/10/19 05:40 PM
How Many Vehicles Do You Maintain?
by Passport1 - 12/10/19 04:23 PM
Bypass Setting vs Subaru
by Al - 12/10/19 03:10 PM
13 chevy equinox I4 engine oil in filter box
by Fitter30 - 12/10/19 02:04 PM
Driven - Direct Injection Oils
by buster - 12/10/19 01:59 PM
.308 Win or .25-06
by mobilaltima - 12/10/19 01:05 PM
FI cleaners ruin injectors?
by Redright9 - 12/10/19 12:54 PM
Planned Changes at Honda
by The Critic - 12/10/19 12:30 PM
The forgotten Bolens 1253
by Lubener - 12/10/19 11:49 AM
Valvoline High Mileage vs Valvoline Full Synthetic?
by Bettez88 - 12/10/19 10:33 AM
Anything to quiet a noisy Subaru front differential?
by anarchyx34 - 12/10/19 10:15 AM
Consumer Cellular
by CourierDriver - 12/10/19 09:53 AM
Ford 6.2L
by ford46guy - 12/10/19 09:30 AM
2012 Hyundai Santa Fe lights on dash issue
by Urshurak776 - 12/10/19 08:25 AM
Electronic Parking Brakes- Long Term Reliability?
by LoneRanger - 12/10/19 08:17 AM
New Kitchen Faucet Selection: To Pex or Not to Pex ?
by LoneRanger - 12/10/19 07:41 AM
Factory Head Unit/New Speakers
by Duffyjr - 12/10/19 06:35 AM
Valve Stem Carbon Build-up from Oil in DI Engines
by paoester - 12/10/19 03:52 AM
New plugs in 2012 Frontier
by MolaKule - 12/09/19 11:02 PM
possumdog, TwoTrax, Cmac83, Faresca, BucDan
70092 Registered Users
111 registered members (asiancivicmaniac, 69Torino, AC1DD, 2010Civic, 4WD, Aichiguy, 6 invisible), 1,859 guests, and 23 spiders.
Topics298,546
Posts5,137,720
Members70,092
Most Online3,589
Nov 2nd, 2019
Which ATF for Mazda MPV? #2997156 05/09/13 09:18 AM
H
HiccaBurp Offline OP
H
We have an '04 Mazda MPV with 86k on original ATF. I was going to start doing some drain and fills, not a complete flush. I believe the factory fluid is Merc3/dex3?? It is a Ford engine/tranny I believe.
What fluid is the best recommended? If I wanted to go full synthetic, which one? And can I do drain and refills using fully synthetic ATF?
Thanks!
08 Toyota Sequoia 5.7 Lim | 106k | Dino | 6k OCI
07 Toyota Prius Touring Pkg 3 | 65k | M1 5w-30 | 15k OCI
03 Chevy Express EXT 3500 | M1 5w-30 | 5k OCI
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2997197 05/09/13 09:53 AM
J
JC1 Offline
J
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Which ATF for Mazda MPV? [Re: JC1] #2997246 05/09/13 10:31 AM
H
H
Originally Posted By: JC1
Sounds great, thx. Is it ok to just drain and refill with it? I wasn't planning on doing a full flush.
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2997357 05/09/13 12:28 PM
I
Ibrahim Offline
I
Yes Absolutely! I would Drain & Fill every 2 years or 40K km's (under normal driving conditions). MaxLife ATF - excellent choice!
Edge EP 5W30
12' Sonata 2.0T Limited
Pennzoil ULTRA 5W20
13' Sonata
HG Ultimate 0W20
18' CR-V
OF: Fram Ultra
AF: ProDry-S
GOLD PLUG
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2997511 05/09/13 03:00 PM
H
H
One more questions.. P/S fluid? I think it calls for merc/dex 3 as well. Should I just drain the reservoir and fill with MaxLife ATF?
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2997640 05/09/13 05:20 PM
M
mrplavick Offline
M
Try pulling the ATF dipstick and look carefully. On my Mazda6 the fluid type is etched onto the dipstick.
And don't fear the multi-vehicle fluids from Valvoline or Castrol.
2012 Mazda3 Skyactiv
Re: Which ATF for Mazda MPV? [Re: mrplavick] #2997680 05/09/13 06:06 PM
H
H
I already drained and refilled today with Valvoline MaxLife ATF. I'll do a drain and refill the next couple of oil changes.. this should get mostly new fluid in there.
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2997705 05/09/13 06:28 PM
Spazdog Offline
I think it's the same JATCO 5 speed that the Mazda 6 uses shrug
The Mazda 6 5 speed auto specifies Mazda M-V. (M-V, not MerconV)
I could be wrong about the MPV shrug definitely check the stick.
2013 Chevrolet Cruze Eco - dealer Dexos
2014 Chrysler 200S - Whatever the dealer put in it.
1987 Honda CN250 Helix - Penn Platinum Euro5W40
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2998047 05/10/13 05:58 AM
E
ET16 Offline
E
I have an '03 MPV, and I agree with the Maxlife recommendations. It's better than anything else I've tried.
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2998057 05/10/13 06:13 AM
A
ARHND Offline
A
You could safely go with Kendall VERSATRANS ATF
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2998693 05/10/13 07:40 PM
M
Mark_Walk Offline
M
If it uses Mazda M-V (M5) fluid I would not use anything but the factory fill. And it is definitely different from MerconV. Mazda had to issue a TSB due to the confusion. Lot's of discussion on different Mazda forums about this. Here is one of my threads from a few years ago about this same topic.
http://mazda3revolution.com/forums/2010-...servations.html
2011 BMW328xi (M1 0w40) 118,000mi
2010 Mazda6iTP (SYNPWR 5w20) 151,000mi
2007 VolvoXC70 (M1 0w40) 141,000mi
2002 TrailBlazerEXT (PYB 5w30) 155,000mi
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #2999738 05/12/13 07:43 AM
E
ET16 Offline
E
I would.
Re: Which ATF for Mazda MPV? [Re: HiccaBurp] #3130884 09/20/13 04:21 PM
P
Pele Offline
P
I also have a Mazda MPV (2003)
It's a Jatco JA5A-EL Transmission.
Same transmission as used in several other applications with different names:
Mazda6 (Different model number "JF506E"; Different electrical connectors.)
VW Golf/GTI/Jetta (Called the "09A")
Land Rover Freelander
Jaguar X-Type
Owner's Manual for the MPV says to use ATF M-III or equivalent (Dexron 3)
Service manual confirms this on pages 05-17-23 "Automatic Transaxle Fluid - Inspection and Replacement" as well as 05-50-1 "Transmission/Transaxle Technical Data"
I've read that the M does NOT stand for Mercon, which is usually used in Ford products.
VW Specs an OEM fluid, number "G 052 990 A2"
Jaguar specs an OEM fluid number "C2S 12120"
Land Rover specs an Esso part number, a Shell part number, an Idemitsu part number, Mercon V, and a Jatco proprietary fluid.
Some other Jatcos spec a weird "Matic S, K or D" fluid that I've never heard of. But that appears to be a Nissan OEM fluid.
Then I've found this:
http://www.automotoroil.com/atf/atf-auto...l-jf506e-fluid/
$9 GRAND?! I can buy two of my vans for that price.
Anyhow... Being that it's the same transmission across many makes, there should be one fluid that meets all of the above specs...
Many people report running this:
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9012226&contentId=7028224
It meets the requirements of some vehicles including Mercon V... However it does not mention Mazda's M-III, nor does it mention compatibility with the VW, Jag, or Rover fluids.
I'm currently having shifting issues, so I'm looking at draining and refilling the fluid. I have a Dodge (Cummins Diesel) with an automatic and I have heard of the headaches caused by filling with a wrong spec fluid. (In the Chrysler's case, filling with Dexron or Mercon when the transmission specs ATF+3 or ATF+4.)
Is there an aftermarket fluid that meets Mazda M-III requirement or better? Or am I stuck going to the dealership?
2018 Mazda CX-9
2000 Ford Excursion V10 (Converting to 5.9L Cummins Diesel)
Several Mazda RX-7s
2012 Suzuki DL650 "V-Strom"
Re: Which ATF for Mazda MPV? [Re: Pele] #3133365 09/23/13 10:36 AM
G
GSCJR Offline
G
Jaguar X-Type
Plain old Dex3 is fine for your MPV
07 3.5L VQ35DE NAPA FS 5w-30 ProSelect 21358 150KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 175KM
Re: Which ATF for Mazda MPV? [Re: GSCJR] #3167021 10/25/13 02:16 AM
P
Pele Offline
P
Will I gain anything by using Castrol TransMax Import Fluid over the Dex3?
It's more expensive. Perhaps the lighter wallet will put less strain on the transmission.
Just really trying to smooth out the shifts. They're kinda punchy.
2018 Mazda CX-9
Several Mazda RX-7s
