Hey Guys,
This concerns my woman's FWD 2005 Chevy Cobalt with 120K miles.
She says that it shakes when she's getting off the freeway and applying the brakes, but it doesn't happen all the time. She had the brakes done, a wheel alignment, and the front tires replaced last winter and had a hub or two replaced early last year. I was out of town a lot and told her not to wait for me.
I took it for a quick spin to scope it out. I didn't go on a freeway as, quite frankly, I hate driving that car. We have [censored] broken pavement roads around here and her front end makes a heck of a racket going over bumps and tracks. Her plastic front clip is held on by a prayer as most of the mounting tabs are broken off. I zoomed up and down an industrial drive and the brakes felt fine to me but the front clip rattles seemed to have a metallic sound this time.
I jacked up each corner and spun the wheels. No grabbyness I could feel so I repeated that with her lightly pressing the brake - still good. None of tires had any bulges or slipped belts that I could feel. I yanked the wheels in all directions and none had any steering or bearing play. At the front passenger corner I pulled the wheel and put a dial indicator on the rotor as I maybe felt a ghost of a tug while spinning the wheel. There is about 5 thousandth run out but I didn't feel anything on the road test. The caliper bushings felt solid with no metallic noise when whacking with my fist. While testing the rotor runout I thought I heard a faint clunk while spinning.
While under the car, yanking on things and looking for loose parts, I found play in the axle shafts at the transmission. I don't know a whole lot about FWD cars but I know the axles have to slide in and out to allow for suspension travel. The sloppiness I am getting is vertical and side to side. I only get a bit of in/out travel at the wheel bearing - no side play.
I searched the net for hours trying to find some definitive info on allowable play and testing half-shafts. Most everyone says to check for torn boots or listen for clicks while turning. Between her rattles and my poor hearing I didn't and her boots are fine.
In the hope that you good folks could help I made a short video of the play I am concerned about:
What do you think?
What do you think?
