Originally Posted By: Hokiefyd
Originally Posted By: BlueOvalFitter
Is everyone sitting down? I just got off of the phone with a HQSR (Honda Qualified Service Rep.) who stated, "Honda leaves the decision up to the Honda auto tech as to "IF" the oil filter needs to be replaced at each OCI."
There are legitimate reasons to change a filter sooner than required, and these are reasons that a service technician can identify. If the filter is leaking, you would want to replace it. If the filter has bulged or deformed for whatever reason, you would want to replace it. These are things that a service technican can see as he or she services the vehicle.
Oh, and she stated, "It is nowhere written, nor recommended, in ANY Honda Owners manual to use an oil filter for multiple OCIs."
She is simply mistaken on that, and is not familiar with the "A" and "B" service common on nearly every Honda sold today. You can verify this yourself:
On an "A" service, you change the oil only. On a "B" service, you change the oil, the filter, and inspect a number of other things. In Honda's Maintenance Minder system, the service alerts alternate between "A" and "B", so you are instructed by the car to change the oil filter on every other oil change.
I agree, she had no clue!
If a tech does the required oil filter check as you stated, how does he check inside the filter, the media itself to see if it is too dirty, clogged, or torn in any way? Someone please answer that Q?
Or, does he just "ASSUMES" the filter is ok, from all his vast training on filters being checked from the outside only?
