If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
40 registered members (Bailes1992, 14Accent, blufeb95, bbhero, bachman, berniedd, 1 invisible), 840 guests, and 18 spiders.
Topics303,496
Posts5,235,120
Members71,061
Page 1 of 3 1 2 3
TINY oil filter for WRX! #2983500 04/24/13 08:40 PM
R
rg200amp Offline OP
R
The oil filters for the WRX are by far, the smallest I have seen.
For a turbo 2.5L engine that has a sump of 4.4 qts and a OCI recommendation of 7500 miles, I would expect a larger filter. . . .
This just seals the deal for me in my desire to change the oil every 3000 miles.
My finger touching the base of the filter:
That's one and a half inches of filter length!!!!
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
Re: TINY oil filter for WRX! [Re: rg200amp] #2983515 04/24/13 08:52 PM
Quattro Pete Offline
Wow... that's smaller than the Wix 51358 for my bike, which I thought was pretty small to begin with.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: TINY oil filter for WRX! [Re: rg200amp] #2983526 04/24/13 08:59 PM
S_Walmer Offline
Definitely one of the smallest I've seen, kinda looks like a OEM hyundai filter but smaller, also amazed the WRX only has a 4.4 qt oil capacity, by comparison the T5 in my volvo takes 6 qt and its a 2.5 turbo as well.Very interesting. I would say your plan to go 3k on an oil change is a wise one especially if you plan on running a tune.
09 Volvo C30 127k Amsoil HDD,MTG, PSF, BF ,Sierra AF
14 Mazda CX-5 Touring 68K - Super tech 0w20 + Super tech ST6607 Sierra AF
Re: TINY oil filter for WRX! [Re: rg200amp] #2983532 04/24/13 09:03 PM
spasm3 Offline
Run synthetic for 5k but i'd at least change the filter at 2500-3k.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: TINY oil filter for WRX! [Re: rg200amp] #2983534 04/24/13 09:05 PM
K
KHP Offline
K
Lol don't under estimate that little filter. Been doing 7,500 miles on them and they are pretty good (backed by UOA). A healthy engine don't need much filtration as the oil remains pretty clean.
I've cut a few open and filtration media is pretty dense and well made.
You guys get so fired up about such things.
2011 Impreza WRX Limited (46k Mi): OCI = 7.5K Mi - Pennzoil Ultra 5w/10w30 - OEM blue oil filter/P1 PL14612
Re: TINY oil filter for WRX! [Re: spasm3] #2983547 04/24/13 09:16 PM
R
rg200amp Offline OP
R
No. I's changing it at 3K.
I am tuning this car and have plans to push it to the limits often.
SOLD:
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
Re: TINY oil filter for WRX! [Re: KHP] #2983549 04/24/13 09:16 PM
gathermewool Offline
I've cut one open and filtration media is pretty dense and well made.
Yep, same here.
And send out a sample to determine an appropriate OCI. With the oils you're planning to run, 3k would be a flipping waste...most likely - only a UOA will tell.
Anyway, disregard the "run it for Xk with dino and Yk with synthetic" guys. Blanket statements about OCI don't help. Your motor, running any of the synthetics I mentioned or those you mentioned in your other thread will LIKELY take you well beyond 5k, if this truly will be a second, non-DD vehicle.
Also, from personal experience, I can say the car will be taking you to your limits before you take it to its :P. Seriously, I thought I was driving like a mad man at my first (only, so far) rally cross, but the STI acted like I was taking a leisurely ride through the cones. Again, your tune and driving style may affect your OCI to a minor or major degree. The fact that you'll most likely be up at temp for most of your OCI's will help. The rich tune and possible high temps, not so much.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: TINY oil filter for WRX! [Re: gathermewool] #2983587 04/24/13 09:47 PM
sxg6 Offline
I wouldn't worry about the size of the filter, there is no problem using that filter for at least 5k.
Here's a uoa using that filter for 7,480. Insolubles at .3
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2728443
Another report from the same user who ran that filter for 7,538 miles, insolubles at .3 again.
http://www.bobistheoilguy.com/forums/ubb...rue#Post2558815
I don't recall ever seeing a uoa with an oem subaru filter where I saw elevated insolubles. I would have absolutely no problems running that filter up to 10k, but just my .02.
*Edit- I just realized KHP posted in this thread, and the links above are to his uoa's.
Re: TINY oil filter for WRX! [Re: sxg6] #2983601 04/24/13 10:02 PM
K
KHP Offline
K
Originally Posted By: sxg6
I*Edit- I just realized KHP posted in this thread, and the links above are to his uoa's.
Thanks for digging those up. It's been a while since I've seen those.
Re: TINY oil filter for WRX! [Re: rg200amp] #2983629 04/24/13 10:33 PM
B
bvance554 Offline
B
How much filterable 'dirt' do you all actually think is in your oil anyhow? Uts a perfectly adequate filter. Subaru engineers know so much more than we do.
Re: TINY oil filter for WRX! [Re: rg200amp] #2983643 04/24/13 10:50 PM
Z
zloveraz Offline
Z
Remember it's not the size of the filter but how you use it...
11 G37S, QSUD, microGreen MG101-7
14 BMW F800GS Adventure
Re: TINY oil filter for WRX! [Re: zloveraz] #2983713 04/25/13 01:41 AM
BlueOvalFitter Offline
Motion in the ocean.....how you wiggle the worm........ LOL
Your signature for the WRX should read, "2 Filters, One OCI!" crackmeup
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: TINY oil filter for WRX! [Re: rg200amp] #2983735 04/25/13 04:29 AM
T
Timothy Ferguson Offline
T
The turbos require 3750 mile oil changes by the way. No matter how you drive it.
2017 Honda Ridgeline
2017 Honda Pilot
Re: TINY oil filter for WRX! [Re: rg200amp] #2983741 04/25/13 04:59 AM
N
NHGUY Offline
N
Check the size of a Justy filter sometime.
Re: TINY oil filter for WRX! [Re: rg200amp] #2983780 04/25/13 06:58 AM
R
rjundi Offline
R
Once upon a time our 2005 Legacy GT 5mt wagon(similar 2.5L turbo motor) recommended 7500 miles OCI with dino. I did not believe it so stuck to 4000oci. We likely have same oil filter.
1.5 years latter they reverted recommendation(strong) to 4mo/3750 miles. We now are at 150,000 miles with a a trouble free motor (albeit stock never did Stage 1).
We use whatever dino initially dealer and then a mechanic throws in. Let you know when the turbo blows up smile My current Subie expert is partial to Amalie Wolf's Head. No idea what it is but it still pretty clear after 3500 miles and does not burn a drop. My wife does 1500 miles/month majority of it her 35 mile highway commute each way.
Page 1 of 3 1 2 3
