I just put a California air/fuel sensor (Denso 2349071) on a 2008 Nissan Rogue which I thought was California emission compliant (that's why I ordered a CA one). However when I removed the factory one the original OEM sensor (Denso 2349073) was non-Calif. I didn't want to take the time to send the new one back and exchange it. Now I am wondering if it will make any difference; did I just set myself up for trouble during Washington state emissions inspections and engine operation? Will the CA semsor confuse the engine control module? The two look the same. Just what is the actual difference between the two (other than the CA one being more expensive)? Thanks.
