Vehicle is a 2010 Mazda CX-9, owners manual states the following for use as power steering fluid:
Mazda Genuine ATF M-III, M-V, or equivalent (e.g. Dexron® II)
Both fluids are available from the stealership for $9-10/qt, but i'm sure i can get something better from the local Parts store for less.
I have easy access to Castrol Multi-Vehicle, Mobil JWS 3309, or Mobil 1 ATF.
What would you guys use for maintainance, as i aim to turkey baste and refill every oil change just to keep the fluid fresh.
