We have 34 of these cars here at work in our fleet and we have had 12v battery problems since the get go. Basically after 4-5 days of no/little use the battery voltage drops below 12.1v for an unknown reason. Then the anti theft system goes haywire and the car will not start. The only solution I have found is to remove the neg. battery terminal and replace it to reset the system and then all is well...until the next time. Anyone else with this car having 12v/PATs issues. I have found a bunch on the internet, I wanted to see if anyone here had any insight.
