Last timeI changed the oil in my Dakota I installed a new magnetic drain plug. Just a drain plug I purchased from advance auto parts. It came with a new blue plastic gasket and I intalled it without issue. Last week I was reading on this forum that the plastic drain plug gaskets tend to loosen up overtime. So yesterday I climb under the truck and sure enough the plug is very loose, not leaking, but loose. I tightened it back up but my question is what should I do next time I Change the oil? Can I use a copper or metal gasket with the drainplug? I saved the factory plug with the built in rubber o ring. Should I ditch the magnetic plug and replace it with the factory one? Thanks in advance for any help.
