So I put my 1986 Kawasaki 454Ltd away in November, put seafoam in the gas tank and drove it around for a bit then shut it off and drained both carb bowls. Today I went out to start it up and change the oil. I put the fuel petcock on the Prime position for about 10 seconds then back to ON. Set the choke and turned it over. Started in about 2 seconds, and seemed to be running great. I aired up the tires and drove it around a bit to warm up the oil.
When I got back I drained the old Amsoil 10w40 w/Amsoil filter(nice brown color but was kinda noisy as I could hear lots of clatter) and put in Rotella T6 5w40 w/Napa Gold filter. It was then that I noticed a drop of fuel on the bottom of the left carb.
Upon closer inspection it seems to be coming from the front edge of the bowl. Where the bowl mates to the actual carb. I tightened the screws a bit on hat side of the bowl but they weren't really loose at all. Mb its my imagination but the leak seems to be slower. When sitting a drop forms over about 10 minutes.
My thoughts are that sitting over the winter without fuel touching the bowl gasket has caused it to shrink slightly. This has caused a slight leak.
Plan: Leave it and drive it like this for awhile and hope the gasket will swell slightly and stop leaking. I really don't want to remove the carbs since that was a lot of work when I did it before. Obviously if it continues to leak I'll have no choice but to pull the carbs.
What do you guys think?
