Hello.
This is the truck:
I just put new Hankook Dynapro RF10 tyres on
What I would need to know whether the camber is adjustable in original state?
I ask this because I have received some contradictory information on the subject, for example from the guy who is supposed to do the 4 wheel alignment. He says that there is a drilled hole (in the frame?) that should be modified oval to allow adjustment. As far as I can tell the upper control arms have bolts and eccentric washers which should allow the adjustment.
Can you comment on this or should we just take it apart and have a look by ourselves?
This is the truck:
