Originally Posted By: Tempest
A conventional 75W90 will have a good amount of VII
75w-90 gear oil is equivalent to something like 15w-40 engine oil when it comes to viscosity. If they can make a shear stable 15w-40 mineral oil (think most HDEOs), then they should be able to make a shear stable 75w-90 mineral gear oil, too.
Be aware that the shearing forces in gears are far higher than in engines. Note that gear oils use extreme pressure additives for a reason, and that they are absent in motor oil.
Gears operate in boundary and mixed regimes far more than do engines. The VII in motor oil is also different from those used in gear oils.
