Valvoline MaxLive Dex/Merc ATF is usually carried by Walmart. If it's there then that's probably the cheapest place to get it.
toyo said:I want to hear from owners that have gone 75K to 100K on Maxlife. Heck, just about any type of trans fluid will work for a mere 10 to 15K miles. [/quote
I have gone through from 117K to 185K now, that is close to 70K without any problem.
I did a drain fill at 117K when I bought the Sienna.
Drop pan and fill at 130K,
Cooler flush without dropping the pan at 160K using 12 qts of fluid.
Now at 185K and the fluid is still red.
The sienna have a few pan bolts above the frame so I let mechanics did the pan drop, change the filter and clean the pan at 130K together with timing belt change.
I have also added a Magnefine since 117K.
It looks like I can monitor the color before I need to change it the next time.
So far at 25K, the fluid still looks like new.
