Originally Posted By: SMB
The VANOS gasket was leaking and we changed it.
The Vanos seals or the valve cover gasket?
If it was the Vanos seals, was it a big job? I've seen DIY instructions on the web that seemed fairly complex.
There is a gasket just underneath the VANOS unit that was leaking badly. We also changed the VANOS seals (o-rings) while we were there. It was time consuming but not complex. You can do it just follow the DIY instructions like I did.
Originally Posted By: Brybo86
most pics look good... but what is going on with all the gunk in the last picture?
There was a tiny bit of sludge on the cover. I am thinking the previous owner used dino oil.
Originally Posted By: V8man
I wonder what oil was used before 163,000 miles.
That is the big question. I assume had M1 0w40 been used the entire time there would be very little if any discoloring at all.
I will ask the PO and post here if he knows.
Originally Posted By: wirelessF
I'll be doing the valve cover gasket on my aunts 04 BMW 325i on Friday. Hope it does not look like this.
Please post pictures.
