Any of you had a bad MAP sensor before?
I have an intermittent lean fuel code, got 2 new O2 sensors, new plugs, coil packs are good, fuel pressure is fine, no vacuum leaks.
The car have a rough idle, vibrating when cold, smell of gas sometimes on cold start, when idling, the rpm can go up and down just a bit, and also have intermittent hesitation on maintained highway speed. Also harder on gas.
I suspect the MAP sensor being lazy of not working properly, or the TPS sensor.
What do you guys think? I had the code p2096 several time, which is Lean fuel Trim Bank 1.
