901Memphis
Thread starter
Well i finally got around to getting some of the old fluid out.
Some of you guys might not approve of the methods i use, but i am limited because my apartment has a no car maintenance policy that was recently implemented so i had to ninja change it in the darkness.
My method involved using a vaccum pump to suck 4 quarts out of the dipstick and then i added 4 fresh quarts and drove the car a little while to mix it up. Rinse and repeat and i ended up adding a total of 12 fresh quarts and the 3rd batch i sucked out looked much better.
The first 4 quarts i sucked out looked even darker than i had thought and would rate it as dark brown.
I plan on doing a proper change and a filter change sometime in the future when i can get a place to work on it.
It shifts much softer now with the limited time i had to warm it up and drive it. Before it was shifting much too firm, but now it seems better.
Here are some pictures. I only paid $2,500 for the car and the transmission was the only part my father in law neglected because his mechanic told him since he didn't change it to just leave it in.
Glad i got "most" of the junk out. All pictures are of the first stuff i took out which was in for over 100k miles and 10+ years.
