I'm responsible for a small fleet of five GM trucks and vans, two of which see extreme duty - a '12 Silverado 2500 HD and a '13 Sierra 2500 HD. Both are crew cabs equipped with the Z71 package. This is how the Silverado is equipped, the Sierra has an open bed carrying a ton of stuff with all sorts of heavy spotlights on the roof:
These are animal control vehicles, and I cannot emphasize enough how extreme the conditions are that they operate in. They operate in very fine, soft sand in the desert running in low range most of the time. I run synthetic everything. Transmission fluid temperatures hit over 250 Fahrenheit and it already smells burnt on the Sierra with 10,000 miles on it.
I used to be able to get Motul Multi-ATF, but these units call for Dexron-VI and this is only a Dexron-III based fluid. Their actual Dexron-VI approved fluid is not available, and I'm running ACDelco or Kendall Dexron-VI. The fluid changes are so regular, it is ridiculous, yet at the same time required.
The initial plan is to install much larger ATF coolers, which I'm looking into at the moment. But the other question is, how much of a difference would LubeGard Platinum realistically make under these circumstances?
