One of my co-workers was complaining his 2004ish Mazda3's headlights were cloudy. Sure enough, they were pretty well opaqued. I told him I'd supply the supplies if he could get a buffing wheel for my cordless drill, since we were reviving the headlights in the parking lot at work. The supplies I had not touched for a long time, so it was no big loss to dust them off and use a little bit. Of course, he forgets. So we find a couple of clean rags and carry on by hand.
After rubbing compound, polishing compound, Plast-X, and a top coat of Collinite 476, the headlights were much clearer. Mind you, this was done by hand. If we'd had the drill supplying the motive force, they would have looked almost new. Co-worker was amazed at the difference, as he had tried an expensive "headlight repair kit" that had not touched the oxidation at all. And we had just cleaned his headlights in less than 10 minutes by hand. I told him it would likely need to be touched up in a few months, and he was fine with that.
Still amazed what a few pennies of polishes and waxes will do, even on a fairly neglected headlight.
