Originally Posted By: CourierDriver
Originally Posted By: powayroger
First of all, I’m a fan of Berryman’s B-12 (
http://berrymanproducts.com/ProductsInfo/FuelAdditives.aspx). Been using it for years as a fuel additive. I’ve also been familiar with Seafoam (
http://www.seafoamsales.com/motor-treatment.html). Last week I was at Walmart and it looked like they were closing out on B-12. 3 bottles left at around $2.75 a bottle, but they were now selling seafoam for about $9.00 a bottle.
Aren’t these products pretty much the same? I bought up the last 3 bottles of B-12.
If u type in b 12 cleaner,,the search section goes back to 2002 and maybe 1000 threads on this cleaner,,lots to read.enjoy
Berryman B-12 is stronger than SeaFoam.
SeaFoam is great to shoot into Intake, "kill the engine" DONT rev it up or it will get burned off.. let it sit "An hour" start up.. watch all smoke, thats the carbon. Not so much B12.
Also great to do Piston Soak with Seafoam not B-12 (a little better than MMO there.) Do you fill up the cylinder 100% and turn it then suck it out, or only add 2 ounces to the top?
I narrowly choose SeaFoam.. though i will pour B-12 (2 or 3 cans) into Oil Pan when engine has no Oil at change, wait a half hour, pour a quart or two of cheap oil to gert it out, then refill (drain plug in, let B012 dissolve, remove drain plug, pour oil down to get sludge/clay out of pick-up screen and pump, replace plug, fill Oil!) B-12 is better there.
