Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
119 registered members (555, anndel, 2015_PSD, albenjoseph, 97f150, 69Torino, 15 invisible), 2,118 guests, and 62 spiders.
Topics286,156
Posts4,903,149
Members67,565
Most Online2,967
Mar 10th, 2019
Page 1 of 7 1 2 7
Varnish: Is it really harmless? #2935154
03/11/13 11:36 AM
03/11/13 11:36 AM
Ontario, Canada
OVERKILL Online content OP
OVERKILL  Online Content OP
Ontario, Canada
One thing I've noticed is that on almost any engine that has had some sort of failure, there is always varnish present. Many will and have argued on this board that varnish is harmless. I'm not so sure about that.
A recent thread on Maxbimmer, where a gentleman's M62 had its timing chain guide shatter had me thinking about this. His engine had some rather significant varnish build-up inside (I'm not posting his pics until he gets back to me and says it is OK) and my theory here is that the varnish causes the hydraulic part of the tensioner to stick, allowing the chain to slap the guide, subsequently breaking it.
There was a thread on M5board last year where somebody had a tensioner fail. Again, significant varnish present.
And of course this brings up many questions with respect to BMW's oil choice, end-user oil choice and the like. There are FAR too many cases of varnished BMW engines to assume that they all were using some sub-par lubricant. This is especially true with M5 owners, most of which use the coveted "TWS".
A quick search of S62 guide replacement yielded these pictures:
That's a Toronto car from what I could tell. crzy
An M62:
This supercharged car is an exception (it is clean) but he is doing the guides because he had the dealership do them (and he paid 6K) and one of the bolts backed out.... No mention as to why they were replaced initially.
Another S62:
Thoughts?
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935159
03/11/13 11:42 AM
03/11/13 11:42 AM
Top of Virginia
Hokiefyd Offline
Hokiefyd  Offline
Top of Virginia
I may be in the minority opinion here, but I'd say that the level of varnish depicted above is not causing timing chain tensioner failures. Or if it is, then the BMW tensioners are much more sensitive to varnish than most. Those engines look very clean to me.
Re: Varnish: Is it really harmless? [Re: Hokiefyd] #2935162
03/11/13 11:46 AM
03/11/13 11:46 AM
Ontario, Canada
Ontario, Canada
I would classify the level of varnish in engine #1 (the Toronto one) to be at a significant level. The one below it isn't too bad. The bottom one is somewhere in between.
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935170
03/11/13 11:53 AM
03/11/13 11:53 AM
Orlando, FL
HyundaiGuy Offline
HyundaiGuy  Offline
Orlando, FL
Maybe BMW is sourcing the guides from the same place Peugeot is getting them for the Mini engines. This is a common repair with Mini. Mine had the chain tensioner and guides done at 28K miles and was part of my decision to get rid of it. Just as in one of the above examples, the bolt started to back out.
'18 Fiat 124 Spider Abarth 700 miles factory fill (Mine)
'18 VW Tiguan SE 8k FF OEM Filter (Hers)
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935173
03/11/13 11:55 AM
03/11/13 11:55 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The problem is the absurd path of the timing chain. Way different than one on my old 289 Mustang.
2015 Ford F250 w/Powerstroke
Re: Varnish: Is it really harmless? [Re: Donald] #2935174
03/11/13 11:58 AM
03/11/13 11:58 AM
Ontario, Canada
Ontario, Canada
But not all that far off from the path of the Ford Modular engines wink
Now Ford had guide failures for a few years, but it was because of the quality of the guides. Earlier years didn't have the problem, and neither did later ones.
Re: Varnish: Is it really harmless? [Re: HyundaiGuy] #2935185
03/11/13 12:03 PM
03/11/13 12:03 PM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
A Peugeot engine in the Mini....gulp!
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935194
03/11/13 12:11 PM
03/11/13 12:11 PM
Top of Virginia
Hokiefyd Offline
Hokiefyd  Offline
Top of Virginia
Cadillac's Northstar used three timing chains on each engine; one shorter "jack chain" to an idler shaft near where the camshaft would be in a cam-in-block engine, and then one timing chain that ran to each head. This was done to keep the timing chain runs as short as possible and to avoid what is essentially a 90 degree change in motion. There are VERY few reported failures of the timing chain system on a Northstar engine, despite running long OCIs on conventional ILSAC oil. Maybe there's a correlation there.
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935209
03/11/13 12:27 PM
03/11/13 12:27 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
To me the first picture is boarder line sludge.
I think sludge is harmless in majority of cases, however it is a sign that something is happening to the engine that should not. To me varnish means that OCI's for a given oil choice and application were boarder line acceptable.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935215
03/11/13 12:34 PM
03/11/13 12:34 PM
Hudson, NH
LeakySeals Online content
LeakySeals  Online Content
Hudson, NH
Take a look at any engine pic on here going through a de-sludge/deposit cleanup. Whats underneath the sludge? A heavy layer of varnish. Its no coincidence. Varnish is telling us something about the oil and surface temperatures of the engine. Varnish always mattered, it can glaze cylinder walls, coke rings, make lifters stick. Matters more today. Tighter clearances, smaller oil gallies everywhere. Any sticky buildup in the tiny gallies of the variable valve timing system will cause issues eventually. So while you may be able to live with it, it cannot be ignored as "normal" anymore.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935234
03/11/13 12:47 PM
03/11/13 12:47 PM
Florida
Artem Offline
Artem  Offline
Florida
Hence why I'm trying so hard to clean up the varnish build up (i'm sure its harmless in my engine though, as it's very light) in my 98 Camry V6. popcorn
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935236
03/11/13 12:50 PM
03/11/13 12:50 PM
Ontario, Canada
Ontario, Canada
This is also why I made sure the M5 I bought was clean through the fill hole, FWIW wink
Now, to stir up the hornets nest, most of these engines would have been run on Castrol/BP lubricants popcorn
Re: Varnish: Is it really harmless? [Re: Hokiefyd] #2935246
03/11/13 12:55 PM
03/11/13 12:55 PM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
The Ford 4.0 SOHC V6 has a similar design. They were known for failed chain tensioners for the first few years of production. Ford eventually came out with an updated design that fixed the problem.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Varnish: Is it really harmless? [Re: Hokiefyd] #2935252
03/11/13 12:59 PM
03/11/13 12:59 PM
Ohio
mechanicx Offline
mechanicx  Offline
Ohio
I think so too. Lots or all engines have varying degrees of varnish, but they don't all have early valvetrain failures. Overkill is probably just trying cover for BMW fragility with varnish tongue2.
Re: Varnish: Is it really harmless? [Re: OVERKILL] #2935255
03/11/13 01:01 PM
03/11/13 01:01 PM
Hudson, NH
Hudson, NH
The "C" word. I agree, written about it on here several times. Following high mileage Toyota teardowns/rebuilds for a supposed "oil consumption problem", most of the time all thats found is hardened carbon, hardened varnish in the piston area. Oil used? 90% of the time Castrol something usually GTX or Syntec. I always ask so I'm not just throwing it out there. I think Castrol's flashpoint is too low for modern all aluminum engines.
Page 1 of 7 1 2 7
