Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
2015 Mazda 3 2.0 - Intake Valve Pics
by buster - 12/05/19 03:54 PM
Timemaster had to get fixed...
by dareo - 12/05/19 03:44 PM
Amazon Packaging
by SubLGT - 12/05/19 02:21 PM
msf1344, Tank99, Ronparise, DrPcFix, benny88
70043 Registered Users
81 registered members (264mag, 4WD, 14Accent, 2010Civic, 69GTX, 5 invisible), 1,815 guests, and 65 spiders.
Topics298,350
Posts5,133,540
Members70,043
Most Online3,589
Nov 2nd, 2019
Results of Unholy Mixture. #2933384 03/09/13 08:49 AM
G
GreeCguy Offline OP
G
You guys are going to hate me, but I thought I would post as "food for thought."
History and background: 1993 Ford Taurus GL with the AXOD metric transmission. Transmission has 155,000 miles on it and last fluid change was at 90,000.
Tranny issues are slipping in first gear and a "hesitant" shift between 3rd and 4th. Transmission also "jumps" into drive and reverse.
Changed fluid and filter. Pan had a pretty good coating of "grey clay." Cleaned pan, reinstalled pan and added new fluid. Then, I drove the car several miles, pumped three quarts out with hand pump through filler tube, added three quarts, repeated, until I had removed and added 15 quarts of fluid. Final fluid flush, I added a bottle of "Lucas transmission fix," and drove for a week. Some improvement.
Read about "Lubegard" products. Bought a bottle of Platinum, removed one quart of tranny fluid and added ten oz Lubegard and topped off with fresh tranny fluid, (Advanced Auto DexIII/M. Improvements noticed right away but still some slipping and jumping.
Added bottle of Lubegard Red. More imporvement, but still some slipping and jumping.
Was going to do a total flush again this past week to get back to ground zero so to speak but got very busy. Yesterday, while driving down Hwy 19, transmission started slipped again and developed torque converter shudder, (car would vibrate at intersections and in low gear). Was worried car was going to leave me stranded and I had entirely too much to do yesterday to be stranded. Happened to be at an intersection with Advanced Auto on the corner. Pulled in and bought a bottle of "Seafoam Trans Fix." (I chose Seafoam as it does not have a leak sealer or seal sweller as my tranny is not leaking). Bought a funnel as well and poured bottle into transmission there in the parking lot.
Pulled back onto highway. Tranny REALLY started to slip, (like I was riding the clutch in a standard transmission). Thought, "Now I've really done it." However, within five miles, transmission smoothed out and for the rest of the day, transmission shifted perfectly. No slipping, no shudder, no jumping in and out of drive. On the way home last night, even floored it a few times and the ole gal shifted better than she has in years, (I had forgotten first gear could be so resposive). When shifting into drive or reverse, I can hardly feel it go into gear - very smooth and gentle.
I was going to change out the fluid today, but now I'm thinking of just leaving well enough alone. While I have four gallons of new fluid, I'm thinking at the very least of leaving it in there for a few months to keep doing whatever it's doing and then flush fluid and add a bottle of Lubegard Red.
Comments? Suggestions? Observations? Accusations? I'll taken em all.
"Dyslexics are teople poo!!."
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933387 03/09/13 08:56 AM
E
electrolover Offline
E
I use lucas too. It seems to help a tranny on its last leg
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933395 03/09/13 09:06 AM
P
panthermike Offline
P
I wouldn't go more than a few hundred miles with that mixture. Change it out then and use the LG Red. Sounds like you're trying to squeeze the last bit of life out of this trans, hopefully you can!
'17 Armada Platinum; RGT 0w20, 51K
'19 Ram 1500; Dealer fill, 14K
'70 F100; Valvoline 15w40
Biotech
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933396 03/09/13 09:07 AM
T
Turk Offline
T
Problem is which one did the improvement as one or more of them may have needed some time to work.
Run what you have for a while then change the fluid & add a bottle of LG Red. See what happens & go from there.
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933397 03/09/13 09:10 AM
A
Artem Offline
A
I've also used the Lucas tranny fix with great success. Smoothed out the shifts within a few miles in a bunch of different cars that I've used it on. Can't comment on the other stuff but sounds like that seafoam did the trick for you more then anything else. It's hard to imagine that it's the combination of all the products.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Results of Unholy Mixture. [Re: panthermike] #2933402 03/09/13 09:14 AM
G
GreeCguy Offline OP
G
Exactly Panthermike. Helping support daughter and son in law who have baby on the way, a son in college who eats like Jethro Bodine, (he drinks two gallons of milk a day) and my oldest daughter is getting married this year plus I just sank two grand in my wifes car. Money is very tight in these parts. Thanks for the well wishes smile
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933430 03/09/13 09:36 AM
R
Rolla07 Offline
R
Let us know what you decide and how it works!
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933455 03/09/13 10:11 AM
B
Barkleymut Offline
B
2 gallons of milk?? wow.
Sounds like one of the products helped out for the time being. I have never seen the Seafoam product, but at this point why not try it. Personally as long as the transmission was shifting fine I would leave the current mixture in there. As long as 90% of the mixture is the called for ATF.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933456 03/09/13 10:13 AM
J
jorton Offline
J
GreeC, I have a car that shudders at intersections when stopped in low gear. Next time, would you use the Lucas or Sea Foam first?
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Re: Results of Unholy Mixture. [Re: jorton] #2933548 03/09/13 12:03 PM
M
maybehabitformin Offline
M
Jorton I wouldnt use either in your trans unless its on its last leg.The sea foam may clean something out like the manifold or pressure control solenoid possibly.The lucas I am not sure what it does if anything.If its shuddering use lubeguard, for whatever fluid type you have.If you havent serviced the trans in awhile you may want to do that first and then add lubeguard.
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933615 03/09/13 01:20 PM
W
WishIhadatruck Offline
W
According to the Seafoam website, if you used transtune, then it is safe to leave it in there unless your trans fluid gets dirty looking. That would be a sign that it is cleaning up old deposits and you need to get that out by changing out the fluid. It recommends adding 1/2 bottle at a time. I'd probably change the fluid out soon and keep a close eye on the fluid. It says you can add the other 1/2 of the bottle into the new fluid too.
I've never used it personally. I did by the engine Seafoam once for my lawn tractor at the recommendation of the Kawasaki service tech. He is a friend who does tech support for lawn and garden repair centers and works for Kawasaki.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933655 03/09/13 02:20 PM
G
GreeCguy Offline OP
G
@ Jorton - this entire process has been a learning process for me. I started blindly, knowing I should at least change my fluid and filter and then replace as much fluid as possible. Guy at Autozone recommended Lucas transmission fix, and I thought, for 12 bucks it's worth a shot. It did help some (or seemed to help). Then I started reading and researching. That's when I discovered Lubegard came highly recommmended both here at BITOG and on the Ford Taurus site (TCCA). Figured it was worth a shot. Was then informed problems could be due to varnish in tranny, especially as original tranny fluid was coffee dark when I pulled it out, (more like used motor oil). I had planned on doing another flush this weekend when tranny started acting up at intersection and I was far from home with much to to and panicked.
Knowing what I know now, if I could wind back the clock and do it all over again from scratch, here's what I would do.
Change transmission fluid and filter. Flush transmission in manner I did in first post, (via filler tube). On final flush, add one bottle of Lubegard. Drive a while and see what happens with that. If no change, then I'd try the Seafoam Trans fix.
What attracted me to the Seafoam was the lack of "leak stoppers" as my transmission is not leaking.
If none of the above worked, (And I'd give it more time than what I did - basically I rushed everything because right now, I can't really afford any down time), that's when I'd throw in a bottle of Lucas. It's really thick stuff, (almost like STP oil additive).
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933723 03/09/13 04:06 PM
Donald Online Content
Online Content
Sorry to say, but I think the transmission is on its last legs. Its a 1993 and not worth to rebuild, maybe a used one at a junkyard.
2015 Ford F250 w/Powerstroke
Re: Results of Unholy Mixture. [Re: GreeCguy] #2933788 03/09/13 05:38 PM
F
fdcg27 Offline
F
If this mixture is working, leave it in for a while.
After a few thousand miles, do a pan drop and exchange.
See how it's doing at that point.
You may save this tranny, or you may not.
No way of knowing.
You do know that the Seafoam will at least let the thing live a little longer.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 30K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
